95 del sol turbo tune
ok so i just bought a 95 del sol with a turbo'd d15b and the tune on it is way off is there any kind of at home tune i can do to get it running decent till i can afford to get it to the shop and have it professionally tuned? currently its running pretty doggy and its throwing codes for the map,tps,iat sensors
Incorrect. The only code the stock ecu will throw is the map sensor code once it sees positive manifold pressure.
Concerning a tuning solution, your best bet is to have your ecu chipped/basemaped after you resolved your codes. For more information on the tuning subject, review http://www.phearable.net/tech/efibeginnerguide.html
ok so i tested the tps and here's the results
closed throttle 6.7mv
wot 3.03v
would this indicate a faulty tps
also checked the power and ground wire power was 5v and the groud was good
wot 3.03v
Could be bad but it sounds like someone replaced it and didnt set it properly. Just stuck it on and went with it.
bought a new tps and am still getting the ame readings... so now i really have no clue what to do nomatter where its adjusted at closed throttle i cant get it above 10mv
Tps sensor: http://www.phearable.net/shoppingcar...ies-p-136.html
Make sure you have the correct plug going to the tps... Some people swap the tps and map sensor plugs.
krisfnbs
Mar 17, 2011 04:58 PM
beaver619
Mar 27, 2008 03:18 PM
imlachg1
23
May 5, 2004 02:29 PM
2camsaam
Oct 1, 2002 12:25 AM
