help trying to build a turbo car for the street 550+
Old Sep 3, 2011 | 04:49 AM
EKHatch_617's Avatar
Default help trying to build a turbo car for the street 550+
need help building a 550+ turbo car b20vtec motor sleeved 84mm ported head supertech valvetrain with oversized valves either skunk2 pro1 or tuner 1 cams.
my question is whether to do a high comp or low comp boost setup. car is not going to be a track car prob will get some track passes but is mainly for the weekends on the street. also im trying to know what are things i can do to grab traction on the street as fast as i can and not break it once i have it. will be running on a s300 boost by gear 2.
so my main questions are high or low comp, how can i grip better, and what kinda setup i can do on 93 pump vpower shell gas ask me questions all you want ill respond asap tryna have this built my next summer
Old Sep 3, 2011 | 06:30 AM
EsotericImage's Avatar
Retired Moderator
Default Re: help trying to build a turbo car for the street 550+
well, if your boosting by gear, the tuner can make the changes so that you hook.
you can go either way with a low boost high comp or high boost with low comp.. or be somewhere in the middle.
depends on what you want to do
Old Sep 3, 2011 | 01:52 PM
dantamparacer's Avatar
personally i would go with around 10:1 compression. You could make the power you want on less boost.
as for traction you can fine tune the boost by gear. I would also run a drag radial because the b20 will make a decent amount of torque. Also make sure you have a good alignment, camber will effect the ammount of tire that actually touches the ground
myownworstenemy
Mar 21, 2015 10:46 AM
gs1gsr
Aug 19, 2012 05:42 PM
22's and Man Boobs
May 16, 2007 03:57 PM
iguano
Feb 13, 2005 11:47 AM
DualKnuttz
Mar 14, 2003 06:52 AM
