how much hp can i get out of ls vtec turbo build
hi every 1 i just wanted to get some opinions on how much power i could make on the dyno with my build i have a b18b block with eagle rods and weisco pistons 10-1compression it has a block guard but no sleeves the head is a stock b16 i have 1200cc injectors it will be on race gas if needed now as far as turbo i have a shitty ebay godspeed gt3582 i know there junk but its what i got for now i will soon be buying a s366 once i sleeve the block and set the car up for e85 and also buy cams like i said before i just would like to know what to expect when i go to the dyno thanks
depends man! use a set of stock cams like gsr or ITR cams, not sure but you might be around 250-300whp, double check everything is running right and get it tuned, dep on the turbo and on where and when it spools and what its hp limit is.
its a fresh build im doing it right now so every thing is new expect the turbo the turbo spools at 4500rpm and the hp limit says its 600hp but i dont believe that and its definitely gonna get tuned as soon as i finish
Sleeves are your weak point. Talk to your tuner and see what he recommends. I personally wouldn't push much over 400. Depends on how long you would want it to last.
Buddy has a stock ls bottom end with a gsr head and ctr cams, arp head studs on a Garrett60-1 spoolin turbo mani made 438hp on 14psi on e85 daily driven and has raced his car for over a year and motor still runs strong
thanks every1 thats more or less the numbers i was expecting to hear.every 1 where i live owns evo's so they think im not gonna be making over 250hp lol. and the few hondas that are around are not built,just stock hondas on a full ebay turbo kit on 7 psi= no power lol but thanks again.
man thats awesome looks like it was put together the right way and tuned to perfection.
There's a thread on that godspeed turbo you have around here, wasn't even balanced from the factory
Prolly be the biggest down fall on your setup wish you luck regardless tho
daddie305
Aug 31, 2011 08:39 AM
DRAGLS
Nov 24, 2001 06:35 PM
