B17 > 93 sol mounts
Old Aug 29, 2011 | 10:49 AM
barrett_5's Avatar
Default B17 > 93 sol mounts
I've been searching for a while now but can't seem to find a solid answer. I've got a B17 trans attached to my B18b1 that I'm swapping into my 93 Del Sol Si. What top trans mount should I use? I could get Hasport but they are like $170. Is there an OEM mount I could get from a car in the wrecker? I've heard I could use a DA mount but I've also heard that it won't work. Can someone tell me for sure what OEM mount (if any) I could use, or am I stuck with the Hasport mount?
If it helps, the car is already set for a cable trans so I don't need the hydro clutch relocation junk just the mount.
Old Aug 29, 2011 | 12:48 PM
Hasport's Avatar
Default Re: B17 > 93 sol mounts
there is no oem mount to put a cable transmission into a 92-95 civic/del sol
Old Aug 29, 2011 | 12:52 PM
grumblemarc's Avatar
The Grumpiest
Looks like you'll be coughing up $170.
Old Aug 30, 2011 | 05:31 AM
barrett_5's Avatar
that's what i was afraid of. thanks for the help guys. appreciate it.
Old Aug 30, 2011 | 11:07 AM
Hasport's Avatar
if only the mount is needed it will be cheaper than $170
Old Aug 30, 2011 | 05:07 PM
94EG8's Avatar
Seagull Management
B17A tranny right? The guts will drop right into a hydro case, which you can get for about the same price or less than a set of mounts, you can can then use OEM mounts and not have to deal with a crappy hydro to cable conversion.
wraprail
11
Apr 24, 2016 05:55 PM
JayDeeMmm
Apr 19, 2012 06:06 AM
silverbullet9626
10
Apr 2, 2011 06:45 PM
8520
Jul 25, 2007 01:41 PM
mattL
Jan 7, 2004 11:12 AM
