REPLACING MOUNTS
Old Jan 7, 2004 | 10:28 AM
mattL's Avatar
Default REPLACING MOUNTS
My driverside mount is shot and i need to replace it, should i stick to OEM or buy an aftermarket polyurethane mount, i've found them both for the same price. thanks
Old Jan 7, 2004 | 10:37 AM
JuicedGSR95's Avatar
are you pricing the inserts or the whole mount? if you get a poly mount, I would recomend doing all 3 the same.
Adam
Old Jan 7, 2004 | 10:58 AM
EL Vap133's Avatar
Default Re: REPLACING MOUNTS (mattL)
Polyurethane mounts will not absorb vibrations like the OEM ones do...
Old Jan 7, 2004 | 11:12 AM
mattL's Avatar
Default Re: (JuicedGSR95)
i was looking at replacing the entire driverside mount and also adding the Es inserts. i was wondering if using a poly mount on only one side would have a negative effect.
silverbullet9626
10
Apr 2, 2011 06:45 PM
blazed_racer
18
Jun 25, 2008 05:29 PM
lude98SH
Jul 8, 2007 08:34 AM
DB1_559
Jun 8, 2006 03:52 PM
SwissChEz82
Nov 17, 2004 10:20 AM
