B17 > 93 sol mounts
B17 > 93 sol mounts
I've been searching for a while now but can't seem to find a solid answer. I've got a B17 trans attached to my B18b1 that I'm swapping into my 93 Del Sol Si. What top trans mount should I use? I could get Hasport but they are like $170. Is there an OEM mount I could get from a car in the wrecker? I've heard I could use a DA mount but I've also heard that it won't work. Can someone tell me for sure what OEM mount (if any) I could use, or am I stuck with the Hasport mount?
If it helps, the car is already set for a cable trans so I don't need the hydro clutch relocation junk just the mount.
Seagull Management
Re: B17 > 93 sol mounts
B17A tranny right? The guts will drop right into a hydro case, which you can get for about the same price or less than a set of mounts, you can can then use OEM mounts and not have to deal with a crappy hydro to cable conversion.
silverbullet9626
10
04-02-2011 06:45 PM
