Engine help
Old Aug 24, 2011 | 06:27 PM
wennerjake's Avatar
Default Engine help
hi i am in just took my engine out of my crx a d15, i just bought a d16 vtec. what should i do for wireing. its all different. i think i can take the distributer off and the intake manafold and use the d15 one to make my d15 wireharness work. but will the p28 ecu plug into my stock wires or what???
Old Aug 24, 2011 | 06:34 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: Engine help
Please, do us all a favor and READ... ALL the information you seek is in the FAQs... All of your questions are the same ones that get asked thousands of times over.
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/88-91-crx-ef-civic-frequently-asked-questions-faqs-1508680/
If you want your engine to run right (I assume you have the D16Z6) you will need to convert to OBD-1 and run the P28... Obviously NO, it will not plug into your harness. You have a LOT of research to do. I also assume you are DPFI so you need to do the MPFI swap... You may be in pretty deep - there is a lot tha could go wrong, educate yourself.
Old Aug 24, 2011 | 06:41 PM
turbohatchBnuts's Avatar
your going to have to do a dpfi to mpfi swap then convert it to obd1. start googling.
what the ef
Apr 18, 2010 09:09 PM
Historyg
Nov 5, 2007 02:04 PM
Mark80
Oct 1, 2006 11:55 AM
ITRnorway
May 11, 2005 09:45 AM
JDM97R
Oct 27, 2004 12:07 PM
