what should i do!!??
Old Aug 22, 2011 | 11:31 PM
blackguy503's Avatar
Default what should i do!!??
Hello,
Ive got a red da9 its a 91 RS its all pretty much stock except a stage 2 clutch and exhust.
I know im going to have to lower it and put some rims on it but i dont want to at this moment i would lije to work on the motor.. any suggestions for me at all??
I was thinking of getting B16 head for LS Vtec would that be a waste of money?
Old Aug 22, 2011 | 11:45 PM
Jdmglenn's Avatar
Default Re: what should i do!!??
find a short geared cable tranny, vtec head, bam
Old Aug 24, 2011 | 05:50 PM
FTNW's Avatar
BAM^
Old Aug 24, 2011 | 06:21 PM
turbohf's Avatar
bam.... another slow *** NA honda...
Old Aug 24, 2011 | 08:04 PM
HdeucedeuceA's Avatar
Why waste the time? Go H2B or K-series...BAM
Old Aug 24, 2011 | 11:09 PM
TrueZen's Avatar
K-series, both Hasport and HybridRacing make mounts for that application. Don't waste your time.
Old Aug 25, 2011 | 10:23 AM
ahhwhat?'s Avatar
word!
Old Aug 26, 2011 | 12:07 PM
vtecdc4's Avatar
well there is no point of having a fast car if u cant stop right, i say suspension and braking.
Old Aug 26, 2011 | 12:08 PM
Thats why i need suggestions and i have no money for k swap
Old Aug 26, 2011 | 12:36 PM
turbohf's Avatar
no money to play? then you sit on the sidelines and watch. probably better that way, cuz you'll have a reliable DD lol.
Old Aug 26, 2011 | 07:29 PM
FTNW's Avatar
If you want quick and easy performance parts that will prove them selfs.
body kit, intake, paint job
Youll get all the females
Old Aug 26, 2011 | 07:33 PM
Katastrophic's Avatar
Slap a snail on her and BAM.
Old Aug 26, 2011 | 11:35 PM
Never the sidelines.. i just dont have thousands i can do thousand...
Old Aug 27, 2011 | 09:18 AM
Going LSVTEC isn't as simple as slapping a vtec head onto a none vtec block, to do it right the first time will cost you more then a grand with parts, Tune, etc.
Old Aug 27, 2011 | 09:17 PM
EasternBandit's Avatar
Exactly, most people just starting into builds forget that when you start mix-matching blocks, heads, pistons and cranks you are going to need some sort of engine management.
Old Aug 28, 2011 | 12:39 PM
siR_ish's Avatar
very true ^^^ you could invest in a full gsr swap... or you can go for all looks. basic bolt ons is where i would start if i were you.. keep in mind that you have to pay to play hahaha.. good luck
Old Aug 28, 2011 | 04:53 PM
1998GsRIntegra's Avatar
I'm assuming your just another troll, but in the event your not...you need to do a lot of reading before you make a thread like this. There is at least one thread like this one every day. If you searched you would find answers. In the 10+ years that honda-tech has been around do you really think someone else hasn't asked the same question? Do a lot of reading and use google frequently; you'd be suprised how much you'd learn.
5 seconds worth of searching google yielded me these:
https://honda-tech.com/forums/tech-misc-15/good-first-mods-ls-motor-409856/
http://www.superhonda.com/forum/f86/...-motor-170816/
http://www.superhonda.com/forum/f13/...7-05-a-158156/
muth-33
Jul 7, 2013 12:37 PM
LSxVQ35
Jan 27, 2009 10:38 AM
si_bat
55
Mar 25, 2005 10:40 AM
Whizzard9992
13
Oct 14, 2003 12:48 PM
SinTeg21
Sep 28, 2003 10:11 AM
