purple power degreaser bleached the block..
Old Aug 22, 2011 | 07:11 PM
Wrona's Avatar
Default purple power degreaser bleached the block..
I used it on my block and it bleached my whole block and took off paint from my heat shield how can i get the block tolook normal again
Old Aug 22, 2011 | 07:16 PM
strategy400's Avatar
Default Re: purple power degreaser bleached the block..
I soaked my oil pan and valve cover in it in the sink in my garage overnight. Really made the valve cover look good I thought.
Old Aug 22, 2011 | 07:19 PM
98civdx's Avatar
Master Detailer
I have never heard of this, can you post a picture?
Old Aug 22, 2011 | 07:31 PM
He likely squirted it on the block full strength while the engine was still installed.
Hot tanking the block would probably help and a coat of paint.
Old Aug 22, 2011 | 09:51 PM
Wrona's Avatar
yes the engine was still installed... i was using degreaser because of an oil leak so i put some in a squirt bottle and put some on the block and cleaned up most of my engine bay with it.. the only problem is that my block where it says B18B1 and my dizzy and near the tranny is all faded like crap
ill post pics of it tomorrow
Old Aug 22, 2011 | 09:55 PM
boostedef123's Avatar
Means you need to wet it and scrub its just residue from the purple power.
Old Aug 23, 2011 | 03:29 AM
94blkturbo's Avatar
you can try aluminum bright, just don't get it on anything else. it is acid.
Old Aug 23, 2011 | 05:01 AM
turbodcxbro's Avatar
If your talking about the left over white residue that can just be sprayed off, if its nice and dry then you might have to do some wiping. Full strength PP is some strong $hit!!
Old Aug 23, 2011 | 05:28 AM
Wrona's Avatar
alright yeah ill do that today thank you
jdmkidd23
Paint and Body
Apr 22, 2008 12:32 PM
fastboy559
Nov 3, 2007 06:00 PM
x91crxsix
Jul 28, 2006 10:42 AM
HondaGuy02
Apr 20, 2004 08:43 PM
StorminMatt
Feb 26, 2003 11:36 AM
