93 cx d15b2 swap now stock tranny won't work
Old Aug 21, 2011 | 05:49 PM
xsessiv414's Avatar
Default 93 cx d15b2 swap now stock tranny won't work
I would appreciate any insight into my problem. After many headaches I got the d15b2 motor in and running. I left the stock tranny in which worked fine in the d15b8, but it just won't pull now. I've taken the tranny out 3 times now. replaced the throwout bearing. The hydraulic piston engages the clutch fork fine. I can hear the gears changing with the shifter, but when i let off the clutch while in gear the car won't stall. Absolutely no power reaches the wheels. I switched my ecu from a p05 to a p06 and back. I swapped pressure plates, the clutch looks great and still.....nothing. Please give me some more ideas if you have them.
Old Aug 21, 2011 | 06:37 PM
94EG8's Avatar
Seagull Management
Default Re: 93 cx d15b2 swap now stock tranny won't work
One or both axles aren't seated in the diff most likely.
Old Aug 21, 2011 | 06:59 PM
xsessiv414's Avatar
i Will try that thank you
Old Aug 22, 2011 | 05:53 AM
xsessiv414's Avatar
i checked my axles and the passenger side was out an inch. i used a 2x4, towel and a rubber mallet to finally get it in. Drove my car around the neighborhood for the first time in 3 weeks. thank you so much.
Old Aug 22, 2011 | 09:41 AM
94EG8's Avatar
Seagull Management
ek4si
Transmission & Drivetrain
Jun 13, 2012 06:45 AM
EGLUVN
Jan 4, 2008 05:28 PM
drshottest718
Oct 6, 2006 03:22 AM
90LSpimpin
11
Sep 19, 2004 10:13 AM
Tyson
Jun 10, 2002 06:21 AM
