Brakes Upgrade??
Old Aug 20, 2011 | 11:35 PM
journeyquest's Avatar
Default Brakes Upgrade??
Any easy way to improve the braking on my 90 CRX DX?
Old Aug 20, 2011 | 11:39 PM
EL Vap133's Avatar
Default Re: Brakes Upgrade??
You can go with bigger brakes.
Nooch's Avatar
Replace front pads with better quality pads. Someone I'm sure will chime in with their preference.
Bleed your fluid well.
Replace rear pads with 2nd cheapest pads possible
Old Aug 21, 2011 | 12:09 AM
For now, stuck with the small 13 wheels
Old Aug 21, 2011 | 12:47 AM
xkjnboix's Avatar
use DA knuckles front and rear along with the pro valve. or ( front ) 11" rotors with 17cl15vn calipers. stainless lines for icing on the cake.
Old Aug 21, 2011 | 08:56 AM
turbohatchBnuts's Avatar
you have drum brakes in the back. so upgrade them to disc from an integra. for the front try to get 90-91 civic ex knuckles with brakes. change the proportion valve to a integra one. also you change the master cylinder to a 90-91 civic ex or 90-93 integra. or just go to fastbrakes.com they got some good brake upgrades.
Old Aug 21, 2011 | 10:38 AM
FF for Life's Avatar
DA integra brake swap with proportioning valve. Easy stuff....brake bleed/ rear drum adjustment, new brake fluid and stainless steel brake lines.
Old Aug 21, 2011 | 11:53 AM
Nooch's Avatar
Just checked the site, extremely overpriced for my liking.
Also OP, swapping to integra rear disks won't actually make you stop faster. It's just aesthetics.
Old Aug 21, 2011 | 01:51 PM
i always thought disc brakes are better.
Old Aug 21, 2011 | 02:02 PM
claymonthug's Avatar
there is so much you can do with honda brakes. mix and match hubs, brackets, rotors and calipers. there is tons of info on this. if i printed out every brake combo anyones ever talked about it laterally would weigh more than a ton.
Old Aug 21, 2011 | 03:53 PM
Tyson's Avatar
this is pretty much the best advice.
your stock brakes are not great, theres a lot to be desired, but theres no reason why they cant stop your car safely when they are properly maintained with good pads, clean pistons and fresh fluid.
throwing bigger brakes on is just making your suspension heavier, and spending more money on doing the same thing as i just said above. i mean if you dont use new DA calipers and good pads anyway, then youre actually just throwing junk on.
Old Aug 21, 2011 | 04:08 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Hydraulics owns me... Everyone has a Brain Fart now and then, thanks Tyson.
http://www.pelicanparts.com/techarti...rake_calc2.htm
Old Aug 21, 2011 | 04:48 PM
Tyson's Avatar
hydraulics owns you.
larger MC just means shorter pedal stroke til the same max pressure. not higher pressure.
its all in the head if you think its more pressure. it may be your preference. but its not making your brakes any better on its own.
a larger MC is only needed when you need to push more fluid, like having a larger caliper piston. or else the pedal stroke would be too long. end of story.
Old Aug 21, 2011 | 05:38 PM
90_EX_Civic's Avatar
you will only stop as good as your tires are.
a lot of people forget this also.
Old Aug 21, 2011 | 05:48 PM
Canadian_EF's Avatar
better for cooling and easier to maintain.
just like how drilled/slotted are only better for cooling... and only in a race environment. and they are actually weaker.
drums provide more braking power but heat up rather quickly.
only a low percent of the braking power is directed to the rear anyways...
I hate drums.
nickelz34
Aug 22, 2013 05:07 PM
rexfan
36
Aug 31, 2009 11:43 AM
95_red_dc
Jun 6, 2006 09:48 AM
TeachHist2005
Nov 15, 2003 07:44 PM
