Front brake upgrade
Front brake upgrade
Ive installed the rear disc brakes on my 92 eg hatch but isnt there a bigger brake upgrade i can do to the front ? Like the rear disc brakes i think came off a integra so would the front brakes work from a integra ? If so what do i need to get and would i still be able to use the same drive shafts on my d15b if i had to change whole spindle and everything ?
Re: Front brake upgrade
Yes you can! I think integra GSR front brakes are bigger. The rotors and calipers I mean. Its a common upgrade. Try searching in the search bar. Good luck.
*you may have to upgrade the brake booster to accommodate the bigger brakes.
Seagull Management
'94 - '01 Integra front brakes. Civic EX also works, but the caliper piston is smaller. Use the matching master cylinder, brake booster and proportioning valve from a '94 - '97 Integra RS non-ABS.
streethondar
01-13-2011 05:49 AM
