oil light
Old Aug 17, 2011 | 05:26 AM
Kris's turbo's Avatar
Default oil light
Hey guys when I start up my car the oil light will come on along with the rest of the dash lights but after the other lights turn off the oil light will stay on for 5 to 10 seconds befor eturning off. Can this be sign of things to come?
Old Aug 17, 2011 | 05:42 AM
StreetsideStig's Avatar
Default Re: oil light
I imagine you've checked your oil. It could be the oil pressure switch.
Old Aug 17, 2011 | 05:54 AM
Former User's Avatar
This^ and also measure the oil pressure.
Old Aug 17, 2011 | 06:21 AM
r.etheridge's Avatar
your wire may not be getting a good connection on the pressure switch on the back of the block
Old Aug 17, 2011 | 06:41 AM
In this case, the light would not turn on. The problem is that the light is on when it should not be.
Old Aug 17, 2011 | 07:06 AM
motegicivic's Avatar
When that light comes on and stays on it means you have practically no oil in the car.
Old Aug 17, 2011 | 08:29 AM
No. It means the oil pressure is too low as measured by the switch (or that the oil pressure switch is faulty or the oil pressure switch wire is bad). Low oil pressure can be caused by low oil, as you said, but also a bad oil pump or blocked oil flow.
Old Aug 17, 2011 | 08:47 AM
sde780's Avatar
I wouldn't drive the car again until you fix the problem, you will spin a bearing if your oil pump is about to go.
slow_low_eddie
Apr 17, 2014 06:01 PM
Schultzie
Jul 10, 2010 08:58 PM
Dutch_Mofo
Dec 1, 2008 09:58 PM
sporkcrx
10
Jul 27, 2003 11:54 AM
