Gauge Cluster Lights
theres a power wire going to the dimmer switch. if its not getting power at the dimmer switch then your cluster lights wont work. i had this happen to me when i did a cabin harness swap in my 1988 std ef.
i had a similar problem that i couldnt firgure out for the longest time. you probably have to change the relay for the dash lights. its kinda above the gas pedal under the dash
Also just google 'main relay' and every ****ing picture is exactly it.
No idea what 'sensor' you replaced either.
LOLyouhavefakewheels
11
Feb 1, 2006 07:28 PM
veganej
Aug 26, 2004 06:52 PM
