Is it difficult to remove the AC system from an EJ1?
Old Aug 15, 2011 | 12:14 PM
Blacknight117's Avatar
Default Is it difficult to remove the AC system from an EJ1?
I am thinking about removing my AC system since it does not hold a charge anymore, (last 15 years, cant go wrong lol). Also the fact that I don`t want to spend $300 on a new compressor. Is there anything special that I need to do other than to discharge the system?
Old Aug 15, 2011 | 12:30 PM
DO/\/\O's Avatar
Default Re: Is it difficult to remove the AC system from an EJ1?
Could be done in less than a Hour. Not hard and dont need nothing special if its already discharged
Old Aug 15, 2011 | 12:38 PM
Linked's Avatar
yeah since its discharged it'll save alot of time.
you basically just remove the compressor, condensor, and evaporator from behind the glove compartment
the only challenging feat will be removing lines because they'll be routed through some nooks and crannies that'll make it difficulty to get through
Old Aug 15, 2011 | 04:15 PM
96electronH's Avatar
dude dont do it. you or the next person that owns the car will want ac. i took mine out and i regret it im buying all the stuff to put it back in. but its your choice. its easy to take out and has scrap value.
Old Aug 15, 2011 | 04:25 PM
98cdmej6's Avatar
yea leave it, you wont even know its gone n then your car is just worth less
Old Aug 15, 2011 | 04:27 PM
chicks dont like sweating in your car either
Old Aug 15, 2011 | 05:12 PM
pwebb0207's Avatar
for real. just ditch the compressor belt and you're set.
Old Aug 15, 2011 | 07:48 PM
sde780's Avatar
Cut the belt is the easiest.
I have an extra compressor if you're interested, came off my car but I installed a turbo so it doesn't fit.
Ldo
Aug 10, 2008 05:08 PM
661rex89si
14
Oct 27, 2006 04:03 PM
ROOROWNS
Feb 14, 2005 01:00 PM
hiendgsr
Jun 29, 2004 11:16 PM
type Gendy
Feb 26, 2004 12:31 PM
