d16z6 power!
well im looking at doing the cam in the z6. Whats a good one to go with? Also when i do the cam is there other mods i could do while the engine is apart?
I was gunna see if i could do my timing belt at the same time? any other mods i could do. If i have to take stock stuff off i mise well put better stuff back.
I'd recommend one of bisimoto's mild cams(like stage 1 maybe 2). Typically when you do a cam upgrade you have to upgrade you springs aswell, and at that point might aswell change your valve stem seals(kinda dumb not to). How will you be tuning this after you do the cam upgrade??
Give us a call at the facility. *888-922-6686. Our tech Specialist are on standby waiting to assist you with your performance goals. Mention Honda-Tech to receive a discount.
Looking forward to your call.
If you need help with some choices give us a call at 888-922-6686
