valvetrain preference on boosted d16z6 help?
Old Oct 22, 2008 | 08:27 PM
boosted16z6's Avatar
Default valvetrain preference on boosted d16z6 help?
i wanna upgrade my valvetrain and cam but im runnin 8psi on stock internals do i need to set my timing back a little bit if i get a cam? and also what brand cams and valvetrain compenents are best?
thanx
Old Oct 23, 2008 | 09:22 AM
23hatchturbo's Avatar
Default Re: valvetrain preference on boosted d16z6 help? (boosted16z6)
i have heard alot of good things about the zex cams try the 59300 its working good for alot of people. And for valve train i love ferrara stuff just my choice all the high quality stuff is good s2 supertech ferrara those are my top three they should all work good for you.
For your timming if you put just valve train your fine no changes needed. If you put a new cam in you need to retune your car to see any benifits of the cam. good luck
Old Oct 23, 2008 | 12:48 PM
ExospeedAMcrx's Avatar
Supertech Performance has D16Z6 valvesprings and retainers. Thats what we use in all our D16 builds. Good stuff.
Old Oct 23, 2008 | 07:42 PM
Default Re: valvetrain preference on boosted d16z6 help? (ExospeedAMcrx)
i have heard good things about ferrara... but if i get a cam will i have to upgrade internals because i heard the rods and pistons are only good up to about 240 and im trying to push for 10psi out of my t3/t4 hybrid... im getting a tune and a hondata s300 with p28 tomorrow and gettin 750cc injectors with a 255 fuel pump.
basically... do i need sleeves, rods, pistons, etc...??? lol
Old Oct 24, 2008 | 03:04 AM
97_coupe's Avatar
I have heard nothing but good things from FJT and would consider talking to him and ask him some questions about his packages
http://fjdistributors.com/prod...d=236
Old Oct 24, 2008 | 05:24 AM
Psychoteen101's Avatar
The rods and pistons are rated to 240, but most of the time even less than that will cause failure. Usually the first thing to go will be either the rings or the ring lands. If your gonna have everything apart, id do atleast pistons and rods. Replace the weakest points of the motor. Your valve train will last longer stock than your bottom end will.
purplerain11
Aug 18, 2011 10:30 AM
A-busive
17
Jun 23, 2006 04:28 AM
GdmLaz
Dec 16, 2004 09:21 PM
hatchback19
May 30, 2003 08:24 AM
JDMvtecDRAGSTA
Feb 13, 2002 02:28 PM
