99 Civic loses Power- please help
Old Aug 14, 2011 | 04:02 PM
Joel.Chavez's Avatar
Icon3 99 Civic loses Power- please help
99 Civic EX 5speed coupe.
Speedometer needle was bouncing while on the highway, then it stopped working. Started losing power, stereo shut off, I had the gas pedal to the floor and it wouldn't accelerate. All of this happened within 5 minutes. So I changed the alternator. Then I rechanged in 20 days because the same problem occurred AGAIN. I disconnected the negative terminal on the battery and car shut off RIGHT after I installed new alternator. Codes P1298, P0135, P0500, & P0141....I know there was a recall with the wiring harness near the intake manifold, but my car's VIN # didnt fall in that category and I didnt see anything burned or messed up when I changed intake manifold for performance. I did notice o2 sensor wiring was burned (the one under the car near where the headers and cat meet. I disconnected it and I still have the same problem. Also AC is not working properly. AC only gets cold when I am accelerating on highway. But when I am at a complete stop, only hot air comes out. And when I am at a complete stop, with AC on, it idles near 500 rpm. Please Help! ThankYou!
Old Aug 14, 2011 | 04:18 PM
Former User's Avatar
Default Re: 99 Civic loses Power- please help
Check whether fuse 15 is blown. It sounds like the O2 sensor heater element wire has a short that needs to be fixed.
By the way, only one thread is allowed per topic.
Old Aug 17, 2011 | 10:37 AM
I disconnected the o2 sensor for now but I still have the same problem. Burned the ECU?
Old Aug 17, 2011 | 12:10 PM
virgineg6's Avatar
fix the codes then go from there
Old Aug 17, 2011 | 12:13 PM
CrazyForJDM's Avatar
Old Aug 18, 2011 | 10:13 AM
All the codes came up at the same time... Both o2 sensors, speed sensor, & ELD...
Old Aug 18, 2011 | 10:35 AM
Hello Mr. Chavez,
Why haven't you done this:
------> **CHECK FUSE 15**
Old Sep 9, 2011 | 02:17 PM
Put new Fuse 15.... P1298 code still comes up. I took it to Honda and they don't sell the ELD unit by itself (inside fuse box in engine compartment)... So I went on craigslist... I found an ELD but for an automatic civic... Does it matter whether civic is manual or automatic for the ELD?
Old Sep 9, 2011 | 02:48 PM
Check fuse 15 for voltage.
The ELD rarely goes bad. I think you are wasting money buying an ELD.
Old Sep 9, 2011 | 03:40 PM
Checked fuse 15A .... It's not blown... The 2 tabs look a little purple from heat but it's not blown..
Old Sep 9, 2011 | 04:10 PM
So you didn't test for voltage?
Joel.Chavez
Aug 14, 2011 04:20 PM
Joel.Chavez
Aug 14, 2011 04:15 PM
Joel.Chavez
Aug 14, 2011 03:32 PM
edbistro
Aug 9, 2011 11:33 AM
turbomonkeyexpress
Jul 16, 2004 10:45 AM
