h22 civic driver axle problems
Ok so for some reason I get a vibration at all speeds. My mounts are ok and I have tried different axles including the hasports and using the integra. I put the vehicle on jack stands and put the car on gear and the driver side tire moves up and down at a constant rate and the axle make a knocking sound. Any ideas what it could be. This is all started after a hasport axle broke and when I installed the replacement axle this started. Since then I have tried all I know but no results. Please help, no fun having my car just sitting on my garage.
Unceasing Measure
Re: h22 civic driver axle problems (samelch7)
Have you considered that maybe your wheel or tire could be out of round and that contributed to your original axle breaking? Switch the driver and passenger side tires to make sure they both "go up and down"...whatever that means.
With the car off can you move the tire a la a bad wheel bearing? There are lots of options here, man. Good luck.
Re: h22 civic driver axle problems (Archidictus)
Its not the wheels or the hub bearing I already check them as well as my mounts.....its just that the driver axle for some reason starts vibrating bouncing hardcore so much that just driving at 5mph or more makes my steering wheel and the whole car vibrate/bounce like crazy
Re: h22 civic driver axle problems (djsire)
not the wheels change to some ebay mounts and it seems to vibrate less I wonder if the hasport mounts would work fine and cause me not problem
sorry for not posting sooner but the actual problem was that the tranny was pressing up on the mount bracket about 1/4 on inch and on the frame as well just grind and punch it with a hammer and it all clear no more vibration or broken axles ......... sure was a bltch to figure out got to make sure U got clearance
