95 Civic Code 7 TPS CEL - HELP!!
Old Aug 14, 2011 | 01:05 PM
boostjunkieee's Avatar
Default 95 Civic Code 7 TPS CEL - HELP!!
I have a 95 Civic coupe with a JDM H22a swap and im getting a Code 7 CEL - Throttle Position Sensor. I checked the voltage at the sensor and its reading .004v with the throttle closed and 3.3v at wide open throttle. I've researched and found it should be .4-.5 closed and 4.5-5 at WOT. I adjsuted the TPS but the voltage only drops lower. The car idle's and runs fine, but it keeps throwing the CEL, does the TPS need replaced because of the lower voltage? Is it starting to go bad?
Old Aug 14, 2011 | 02:02 PM
Former User's Avatar
Default Re: 95 Civic Code 7 TPS CEL - HELP!!
If you unplug the TPS and turn the key to ON(II), what output (reference) voltage do you read at the relevant wire terminal in the wire harness connector?
Old Aug 15, 2011 | 11:29 AM
It reads .025v in this situation.
Old Aug 16, 2011 | 05:55 AM
Can anyone help?
Old Aug 16, 2011 | 07:27 PM
bump...
Old Aug 16, 2011 | 09:03 PM
What color wire in the TPS connector had 0.025V?
Old Aug 17, 2011 | 09:23 AM
The center wire in the connector, I believe its red/blue.
Old Aug 17, 2011 | 09:41 AM
Unplug the TPS connector and measure voltage to body ground at the Yel/Wht wire terminal in the connector. Next do the same test but use the Grn/Wht wire as ground. What are the voltages?
Old Aug 17, 2011 | 07:46 PM
Yel/Wht reads 4.95v, Grn/Wht reads .008v
Old Aug 17, 2011 | 07:53 PM
That's good so far, but you did not use two different grounds:
Do you read the same voltage using these two grounds to measure voltage at the Yel/Wht wire??
Old Aug 17, 2011 | 08:39 PM
Oh my bad, I read your post wrong. I will check it using the other wire as the ground first thing in the morning.
Old Aug 18, 2011 | 11:58 AM
Using the Grn/Wht wire as the ground, the Yel/Wht reads 4.92v
Old Aug 18, 2011 | 12:04 PM
That's good voltage and ground from the ECU. Sounds like a bad TPS. But first verify that the middle TPS wire does not have a short (continuity to body ground with key off).
Old Aug 18, 2011 | 08:46 PM
I will check for a short. Thanks for all the help RonJ, much appriciated!
xander1100
Aug 17, 2009 12:10 AM
EkLanta
Nov 5, 2007 04:38 AM
dsadas89das78934
11
Aug 27, 2004 06:47 AM
