95 Civic Code 7 TPS CEL - HELP!!
I have a 95 Civic coupe with a JDM H22a swap and im getting a Code 7 CEL - Throttle Position Sensor. I checked the voltage at the sensor and its reading .004v with the throttle closed and 3.3v at wide open throttle. I've researched and found it should be .4-.5 closed and 4.5-5 at WOT. I adjsuted the TPS but the voltage only drops lower. The car idle's and runs fine, but it keeps throwing the CEL, does the TPS need replaced because of the lower voltage? Is it starting to go bad?
Re: 95 Civic Code 7 TPS CEL - HELP!!
If you unplug the TPS and turn the key to ON(II), what output (reference) voltage do you read at the relevant wire terminal in the wire harness connector?
That's good so far, but you did not use two different grounds:
Do you read the same voltage using these two grounds to measure voltage at the Yel/Wht wire??
dsadas89das78934
11
08-27-2004 06:47 AM
