Best way to fix a crank and pulley?
Old Aug 14, 2011 | 09:43 AM
92CivicLX15's Avatar
Icon2 Best way to fix a crank and pulley?
Here are some pictures of the situation. Obviously the pulley USED to have a notch in it, but it's gone. I have no idea where the woodruff key is. Can I get by with replacing the pulley, key and maybe using a metal compound to fix the shaft? Or am I going to have to replace the shaft entirely. I deliver pizzas in this car, so I need it to work, but I don't want to put a ton of money into it. Thanks everyone.
http://www.flickr.com/photos/66371395@N04/6042540364/
http://www.flickr.com/photos/66371395@N04/6042542208/
Old Aug 14, 2011 | 11:32 AM
Former User's Avatar
Default Re: Best way to fix a crank and pulley?
You did not post a picture of the most important damage -- to the crankshaft. The pulley is easy to replace.
Old Aug 14, 2011 | 11:46 AM
The second picture is the crankshaft.
Old Aug 14, 2011 | 11:48 AM
Do you also have a less close up picture?
Old Aug 14, 2011 | 11:55 AM
Here is one a little further away.
Thanks
http://www.flickr.com/photos/66371395@N04/6043020156/
Old Aug 14, 2011 | 11:58 AM
apexi_rsx's Avatar
that crankshaft looks beyond repair and the crank pulley has no tooth. it looks like it was rode messed up for a while . looks like u need a new bottom end. if ur not too mechanically incline or rebuilt a motor before i would not recommend u changing the crankshaft out yourself but i would have a shop do it. most d series motors are a dime a dozen and would be cheaper and easier to swap ur own junk yard motor in. then having a mechanic replace the crankshaft which would probably cost more.
Old Aug 14, 2011 | 12:00 PM
Thanks
Why isn't the end of the crankshaft protruding outward from the block? Or have you not removed the lower timing belt cover?
Originally Posted by apexi_rsx
that crankshaft looks beyond repair and the crank pulley has no tooth. it looks like it was rode like this for a while. looks like u need a new bottom end. if ur not too mechanically incline and rebuilt a motor before i would not recommend u changing the crankshaft out yourself but i would have a shop do it.
I'd agree if more pictures confirm a severely damaged crankshaft end.
Old Aug 14, 2011 | 12:02 PM
I have done head gaskets and things, but never rebuilt a motor. Someone said all I needed to do was drop the oil pan, unbolt the crank, put a new one in and replace the oil pan. I guess he left out some details? Haha. To craigslist it goes. I don't think the car is worth paying a shop for an engine rebuild.
Old Aug 14, 2011 | 12:05 PM
Yes, the timing belt cover is still on.
Thanks
Old Aug 14, 2011 | 12:07 PM
Thanks
Remove the cover and post some clear pictures of the crankshaft end so that we can fully evaluate its condition. The answer may be the same but it's worth a shot.
hondamark35
Apr 26, 2011 08:10 PM
tag0617
Apr 12, 2009 06:13 PM
BlUAc
Jan 28, 2008 03:51 AM
david90
Aug 15, 2003 01:15 PM
