Best way to fix a crank and pulley?
Here are some pictures of the situation. Obviously the pulley USED to have a notch in it, but it's gone. I have no idea where the woodruff key is. Can I get by with replacing the pulley, key and maybe using a metal compound to fix the shaft? Or am I going to have to replace the shaft entirely. I deliver pizzas in this car, so I need it to work, but I don't want to put a ton of money into it. Thanks everyone.
http://www.flickr.com/photos/66371395@N04/6042540364/
http://www.flickr.com/photos/66371395@N04/6042542208/
Re: Best way to fix a crank and pulley?
that crankshaft looks beyond repair and the crank pulley has no tooth. it looks like it was rode messed up for a while . looks like u need a new bottom end. if ur not too mechanically incline or rebuilt a motor before i would not recommend u changing the crankshaft out yourself but i would have a shop do it. most d series motors are a dime a dozen and would be cheaper and easier to swap ur own junk yard motor in. then having a mechanic replace the crankshaft which would probably cost more.
that crankshaft looks beyond repair and the crank pulley has no tooth. it looks like it was rode like this for a while. looks like u need a new bottom end. if ur not too mechanically incline and rebuilt a motor before i would not recommend u changing the crankshaft out yourself but i would have a shop do it.
I have done head gaskets and things, but never rebuilt a motor. Someone said all I needed to do was drop the oil pan, unbolt the crank, put a new one in and replace the oil pan. I guess he left out some details? Haha. To craigslist it goes. I don't think the car is worth paying a shop for an engine rebuild.
