H22 into Del Sol swap. Where to run Cable Linkage?
Old Aug 10, 2011 | 03:31 PM
9k Swag's Avatar
Default H22 into Del Sol swap. Where to run Cable Linkage?
I am having problems running my cable linkage in my h22 swapped del sol. I used linkage off a 93 accord and it is about 3 inches too short. I routed it between the the core support and the floorboard by the firewall. It comes up behind the tranny mount and links up with the transmission. I don't see any other logical way to do this...
Where have you guys run your shift linkage cables in your h22 swaps? Also, is there any linkage longer than an accord's? Everywhere I have read says to use accord linkage in eg swaps...but eg shifters are two inches farther up than del sols.
I can post pics of my set up if it would help
Old Aug 10, 2011 | 06:34 PM
94EG8's Avatar
Seagull Management
Default Re: H22 into Del Sol swap. Where to run Cable Linkage?
It may.
Old Aug 11, 2011 | 07:18 PM
H25's Avatar
H25
Same way you would any H series swap. Run the shifter cables under the exhaust tunnel and have them poke through right behind the rear cross beam.
9k Swag
Aug 8, 2011 11:08 AM
T Thrash 09
Jul 18, 2009 03:30 PM
markspan6243
Feb 15, 2009 05:48 PM
M E G A
19
Aug 22, 2007 11:35 AM
pilmpd
Apr 29, 2006 11:07 AM
