3 wire IACV...converting??
so i installed a y8 head on to my d16a6. also installed the y8 intake manifold. i have the auto intake manifold where the iacv is in the throttle body and not mounted to the intake it self
can anyone help me out as far as converting my 2 pin to 3 pin. I have seen lots of stuff bout converting from 3 to 2 but not the other way..
if anyone has info please let me know
thx
thx
alright, well i went ahead and drilled my own holes for the iacv. alot easier than i thought. makes a couple measurements. i used a paint marker on the gasket to mark where the holes need to be.then used the tb gasket to match the angle at which i needed to drill for the airbypass thru the tb.
oh and drilled and tapped the second mounting hole.
so heads up if anyone runs into this problem. its easy fix
Jdog455
Jul 25, 2013 01:14 AM
95boostedh22
Apr 12, 2009 07:55 AM
Rodzknight
17
Feb 27, 2008 09:06 AM
