locking flywheel from moving?
Old Aug 8, 2011 | 10:16 PM
cibao2ner's Avatar
Default locking flywheel from moving?
how can i lock flywheel so i cant torque the damper...not oem so i can used the hex key...anybody know of a good tool that i can use to lock flywheel? a part number maybe?
need to install timing belt..torque fluidamper and flywheel bolts...engine is on engine stand so i need a way to keep it from moving
Old Aug 9, 2011 | 07:10 AM
Organization's Avatar
Default Re: locking flywheel from moving?
i actually took a piece of flat bar or meatal and drilled 2 holes equall to 2 flywheel bolts and bolt it in (mines actual has a lil more work and creativity)
the bar will hit one arm of the engine stand bracket that holds the engine-in return stoping the crank from spin
Old Aug 9, 2011 | 07:11 AM
or get an impact wrench
xduB95preludeSi
Sep 9, 2016 06:37 AM
.Thomas
Jan 16, 2007 10:45 PM
integraautox
Dec 24, 2003 06:14 PM
rOby
Dec 29, 2002 07:43 AM
Dr Pooface
Jan 31, 2002 06:07 AM
