Flywheel install questions?!?
Old Dec 28, 2002 | 08:26 PM
rOby's Avatar
Default Flywheel install questions?!?
ok so im getn ready to get motor to drop into car, soo i need to put flywheel /clutch back on then the tranny. anyhow, how hard do ya torque the flywheel bolts on a gsr tranny? ..the helms says 75 lbs. the prob is, i have no way of stoping the flywheel from spining as i try to torque. i cant find the Ring Gear Holder to stop the flywheel from moving...any suggestions? none of the parts stores have em..sigh
Old Dec 28, 2002 | 08:48 PM
ninesecrx's Avatar
Default Re: Flywheel install questions?!? (rOby)
make a strap. One screws into where the flywheel goes and one goes onto the block. You should be able to be ghetto though and put a screwdriver in and wedge against the block and ring gear. Or you also can just put a wrench on the crank pulley bolt...that will hold the crank as well.
Old Dec 28, 2002 | 08:53 PM
rOby's Avatar
Default Re: Flywheel install questions?!? (ninesecrx)
so could i just have someone get a wrench n socket and hold on to crank pulley bolt? would this suffice to allow me to tighten the flywheel bolts?
thanks for info mike
Old Dec 28, 2002 | 10:47 PM
cock head's Avatar
put a bolt in the engine where the tranny connects, put a pry bar in the flywheel tooth, that will hond it in place, just dont rest the pry bar or screw driver on the dowl pin. I dont use the bolt i actually use the pully if you look at it it looks like a big bolt will fit in their, get a tool that will fit in their to hold it, and that will work also.
Old Dec 29, 2002 | 07:43 AM
boostaholic's Avatar
Yes that will work. Moroso also makes a crank pulley tool that you can use to hold the crank pulley still while you torque the flywheel bolts down. Remember to torque them down in stages.
.Thomas
Jan 16, 2007 10:45 PM
ITR-2001
Aug 16, 2006 02:02 PM
Scooby
Jun 28, 2002 01:07 PM
Dr Pooface
Jan 31, 2002 06:07 AM
