Finding a oil leak
Old Aug 8, 2011 | 06:00 PM
JDM-KIDD's Avatar
Default Finding a oil leak
any one got any tips on finding a oil leak? its so bad and annoying cause it leaks right on the header so it smokes really bad if i driveit normal it doesnt smoke bad but if i get on it it looks like its on fire! lol its just really annoying and wanna c if ne one has any tips on finding leaks
Old Aug 8, 2011 | 06:02 PM
JDM-KIDD's Avatar
Default Re: Finding a oil leak
plus the big *** oil spot i get on the street lol.... just replaced the valve cover gasket and oil pan gasket cause they were leaking
Old Aug 8, 2011 | 06:03 PM
grumblemarc's Avatar
The Grumpiest
Clean the engine off then jack up the car, get under it and wait. Or you can lay cardboard underneath to give you the general location of the leak. Initially check the valve cover and headgaskets.
Old Aug 8, 2011 | 06:16 PM
__oversea's Avatar
Put dye and use black light.
Old Aug 8, 2011 | 06:17 PM
JDM-KIDD's Avatar
thats not gonna mess anything up?
Old Aug 9, 2011 | 05:39 AM
The Grumpiest
It's done all the time.
Old Aug 9, 2011 | 06:22 AM
funhouse75's Avatar
start at the top and work your way down. may have to move some things around to get a better view. Be careful when doing this on a hot engine. I suggest to let the engine cool first. Pay close attention to valve cover gasket and cam seals.
Old Aug 9, 2011 | 07:14 AM
Organization's Avatar
check cam seals on both sides and distributer seal,vtec solenoid gasket and when installing new gasket make sure surfaces are flat and clean so use brake cleaner and a razor blade
i would start by clean the engine really good back and front then turn it on and wait
Old Aug 9, 2011 | 07:45 AM
Builda'Teg_92's Avatar
ok heres what ya do, get under there clean everything. Let the car run for a good few minutes, until you see a drip on the floor. After that get back under the car and blow or throw baby powder at the general location and it should lead you straight to the leak.
Old Aug 9, 2011 | 08:50 AM
bgioan's Avatar
Having a similar problem. I wanted to use a steam cleaner but I have no idea where to get one from other than having to actually buy one. What do you mean by when you say to "clean" the oil off. With what exactly?
Old Aug 9, 2011 | 02:32 PM
water/soap(degreaser)
curtie94
Jul 9, 2011 09:16 PM
jolt-tsp
Jun 3, 2010 07:31 PM
EkFG
Mar 15, 2008 07:47 PM
ajth87
Jun 29, 2006 12:59 PM
Cuong-nutz
Jul 8, 2005 10:41 AM
