Overheating issues with a turbo build that still has A/C and PS
Old Aug 5, 2011 | 01:12 PM
PhillyDelSol's Avatar
Default Overheating issues with a turbo build that still has A/C and PS
So I just got my car back from the shop again. First time I tried to drive it it was 110 degrees out and the coolant temp hit 245 degrees and blew out the oil pan gasket. That's been replaced. Now I need to figure out how to keep this thing from overheating.
As I'm sure I'll get blasted for it...yes it still has AC (the guy who did the turbo kit went ballistic when I told him I wanted to keep it, also has PS).
My question is what are my options? I know the best idea would be yanking the AC and putting a full size rad in but I'd love to keep the AC if possible. Any ideas guys?
Old Aug 5, 2011 | 01:43 PM
Default Re: Overheating issues with a turbo build that still has A/C and PS
It'd probably help if I told you what my setup is...
Built B16 w/Wiseco Pistons, Eagle Rods and OEM crank.
Supertech springs/retainers
Precision 3231E Turbo .63 A/R
Tial BOV & Wastegate w/dump pipe
Custom Log Manifold & Downpipe (Cat-delete)
FMIC
Custom intercooler piping & Oil Lines
OEM size aftermarket radiator (eBay purchase)
OEM thermostat
Competition Clutch Stage 2 Clutch & Pressure Plate
Old Aug 5, 2011 | 03:32 PM
B18CivicEJ8's Avatar
FMIC
OEM thermostat
I run a built GSR w/ Turbo in AZ. I had to upgrade to a dual core aluminum half size radiator.
http://www.mishimoto.com/honda-civic...nce-92-00.html
I also run a Mishimoto thermostat and fan switch.
http://www.mishimoto.com/honda-civic...mostat-92.html
http://www.mishimoto.com/mishimoto-h...mo-switch.html
I also used a turbo blanket for my turbo.
I run 50/50 coolant mix with Water Wetter using the instructions on the Water Wetter bottle. I don't overheat at all anymore.
Old Aug 5, 2011 | 04:34 PM
motegicivic's Avatar
If he runs an upgraded rad, will it take up too much room for the condenser, since he is still running AC.
Old Aug 5, 2011 | 07:47 PM
Frozen E's Avatar
H-T White Ops
Don't think so. The dual cores (Like the Del Sol one for example) will fit into the stock location. They'll just have an extra row of passes. The width is the same as a single pass one.
Old Aug 7, 2011 | 06:42 PM
I already have a dual core. It isn't cutting it. I'm thinking of putting the mishimoto thermostat and fan switch in and see if that works.
Old Aug 7, 2011 | 06:44 PM
Former User's Avatar
Thread copied to the Forced Induction forum.
Old Aug 7, 2011 | 08:07 PM
Thanks
PhillyDelSol
Oct 2, 2011 08:30 AM
sdobson910
Apr 20, 2011 03:59 PM
Speed Infliction
Jan 26, 2007 06:01 PM
Speed Infliction
Jan 1, 2007 02:07 PM
TOP_END_Turbo_GSR
May 26, 2006 10:38 AM
