Drag Alignment
Old Aug 3, 2011 | 06:40 AM
Muckman's Avatar
Moderator in Chief
Icon6 Drag Alignment
Can anybody suggest alignment settings that I can start out with for drag use? I realize every car/driver is going to be different but I need something reasonable to start with. The car is 500hp Integra street car. I don’t care about autocross or turning. I want straight line traction and high speed stability. I’m running drag radials now and eventually slicks. I have full-race traction bars, and front and rear camber adjustment. I have 400lbs springs all around with Koni Yellows (I know not the best drag suspension).
From my research I have found that some negative camber up front is good as it will flatten out when launching. However I don’t know how much my front end lifts so I don’t know how much camber to start with. I’m guessing -0.5 to -1.0* front camber?
And what about toe? I’ve read the front suspension pulls forward so toe out is recommended. However is this statement still true with traction bars? I’ve read 1/16" of front toe out is recommended per side, is that OK?
And I assume whatever camber in the rear is fine, probably 0*. What about toe in on the rear for stability? How much per side?
Old Aug 3, 2011 | 08:46 AM
4cylfiend's Avatar
Default Re: Drag Alignment
Here you go man. This should be helpful.
https://honda-tech.com/forums/drag-racing-36/aligment-specs-2907665/
Old Aug 3, 2011 | 09:07 AM
Muckman's Avatar
Moderator in Chief
Thanks. Do you think the front suspension "toes in" even with traction bars?
Old Aug 3, 2011 | 09:15 AM
tepid1's Avatar
Yes it does. That's why you offset the toe even with bars. With your power level it may not be that bad though.
Old Aug 3, 2011 | 09:16 AM
4cylfiend's Avatar
^yep.
Old Aug 3, 2011 | 10:20 PM
Boosted_B_Series's Avatar
Are you pushing or pulling with the bars?
Old Aug 4, 2011 | 04:05 AM
tepid1's Avatar
Since the front wheels pull forward you push back on the LCA with the traction bars.
Old Aug 4, 2011 | 05:38 AM
E Town DSM's Avatar
That can go either way. Some pull them forward try to extend the wheel base a little more for high end stability. Some push them back for whatever reason. Some leave them neutral. Main thing you dont want to do is bind the suspension up. Just my .02 cents
Old Aug 5, 2011 | 05:18 AM
Muckman's Avatar
Moderator in Chief
So far this is what Ive come up with:
Front Camber: -0.5* each
Front Toe: 1/16" OUT each
Front Caster: As much as possible using traction bars. Make symentical.
Rear Camber: 0.0*
Rear Toe: 1/16" IN each (for high speed stability)
Some people said 1/8" toe out in the front. I am not clear if thats each side or total. 1/16" doesnt seem like alot.
And is the rear toe spec a good choice? Shouldnt be too much to cause tire wear?
Old Aug 5, 2011 | 01:41 PM
Divers's Avatar
^^^From my experience this is correct. When the tire tries to travel forward it compresses the bars and transfers that enegry by pushing the on the front of the car. If the bars were in tension it would aid in LCA movement, which is the exact opposite of what traction bars are suppose to do.
Old Aug 9, 2011 | 11:27 AM
Divers's Avatar
The suspension doesn't "toe-in" under acceleration. As the LCA travels forward it moves away from the rack pulling the rear of the knuckle in and causing "toe-out."
Old Aug 9, 2011 | 12:03 PM
theidealone's Avatar
So wait... Im confused? I always though you were supposed to pull the tires forward with the traction bars (positive caster). Now youre saying to push them back?
Old Aug 9, 2011 | 12:20 PM
Muckman's Avatar
Moderator in Chief
From my understanding, the traction bar pulls the LCA forward with preload tension to create more camber. The toe is set in this forward static position. Then when the LCA attempts to move forward under launch the bar provides compression resistance.
But your explanation of the toe out when the LCA moves forward makes sense to me.
Old Aug 9, 2011 | 12:36 PM
CO_RaceFab's Avatar
I always thought they toed out during acceleration.
Old Aug 9, 2011 | 05:19 PM
Desir Performance's Avatar
From my understanding the traction bar does two things it locks the lca from moving during launch and travel, and by pulling them forward (positive caster) it also increases our wheel base which helps increase traction.
Old Aug 9, 2011 | 05:57 PM
portenio78's Avatar
As much Caster as you can get away with the traction bars.
1/8 TOTAL toe out.
-0.5 degrees negative camber
Old Nov 29, 2012 | 08:42 AM
fg208's Avatar
Can caster be adjusted in the rear of the civic to extend the wheelbase like a traction bar does in pulling/pushing the lower control arm? Or does anyone make this?
I see a lot of drag civics ex. Miller with the rear a bit stretched towards the rear of the car when seen from the side.
88ED8
Feb 5, 2008 08:39 AM
BARTEG
Suspension & Brakes
Mar 23, 2006 05:22 PM
dc2turbo
Mar 17, 2006 10:19 PM
Race Egr
Jun 1, 2005 09:02 PM
GG-SquadDB
Mar 19, 2004 05:45 PM
