Drag Alignment
Moderator in Chief
Can anybody suggest alignment settings that I can start out with for drag use? I realize every car/driver is going to be different but I need something reasonable to start with. The car is 500hp Integra street car. I don’t care about autocross or turning. I want straight line traction and high speed stability. I’m running drag radials now and eventually slicks. I have full-race traction bars, and front and rear camber adjustment. I have 400lbs springs all around with Koni Yellows (I know not the best drag suspension).
From my research I have found that some negative camber up front is good as it will flatten out when launching. However I don’t know how much my front end lifts so I don’t know how much camber to start with. I’m guessing -0.5 to -1.0* front camber?
And what about toe? I’ve read the front suspension pulls forward so toe out is recommended. However is this statement still true with traction bars? I’ve read 1/16" of front toe out is recommended per side, is that OK?
And I assume whatever camber in the rear is fine, probably 0*. What about toe in on the rear for stability? How much per side?
Here you go man. This should be helpful.
https://honda-tech.com/forums/drag-racing-36/aligment-specs-2907665/
That can go either way. Some pull them forward try to extend the wheel base a little more for high end stability. Some push them back for whatever reason. Some leave them neutral. Main thing you dont want to do is bind the suspension up. Just my .02 cents
Moderator in Chief
So far this is what Ive come up with:
Front Camber: -0.5* each
Front Toe: 1/16" OUT each
Front Caster: As much as possible using traction bars. Make symentical.
Rear Camber: 0.0*
Rear Toe: 1/16" IN each (for high speed stability)
Some people said 1/8" toe out in the front. I am not clear if thats each side or total. 1/16" doesnt seem like alot.
And is the rear toe spec a good choice? Shouldnt be too much to cause tire wear?
Rear Camber: 0.0*
^^^From my experience this is correct. When the tire tries to travel forward it compresses the bars and transfers that enegry by pushing the on the front of the car. If the bars were in tension it would aid in LCA movement, which is the exact opposite of what traction bars are suppose to do.
So wait... Im confused? I always though you were supposed to pull the tires forward with the traction bars (positive caster). Now youre saying to push them back?
Moderator in Chief
From my understanding, the traction bar pulls the LCA forward with preload tension to create more camber. The toe is set in this forward static position. Then when the LCA attempts to move forward under launch the bar provides compression resistance.
But your explanation of the toe out when the LCA moves forward makes sense to me.
From my understanding the traction bar does two things it locks the lca from moving during launch and travel, and by pulling them forward (positive caster) it also increases our wheel base which helps increase traction.
Can caster be adjusted in the rear of the civic to extend the wheelbase like a traction bar does in pulling/pushing the lower control arm? Or does anyone make this?
I see a lot of drag civics ex. Miller with the rear a bit stretched towards the rear of the car when seen from the side.
