Can't advance ignition timing?
Old Jul 29, 2011 | 11:12 AM
johnnyboi4o1's Avatar
Default Can't advance ignition timing?
Sup guys I have searched but it seems noone have this problem except me, I have my distributed all the way advance but when I check it with the timing gun the little line on the crank pulley is still at the retard line, then I try moving the distributer the engine stalls out? Any idea would be great and if anybody had this problem, oh yea my car is a 97 cx hatchback everything is bone stock
Old Jul 29, 2011 | 11:40 AM
grumblemarc's Avatar
The Grumpiest
Default Re: Can't advance ignition timing?
Is mechanical timing correct?
Old Jul 29, 2011 | 11:45 AM
Cynical 1's Avatar
have you put it in base timing? followed the procedure in the service manual to do so?
Old Jul 29, 2011 | 12:18 PM
94EG8's Avatar
Seagull Management
Did you jump the service connector under the dash before you tried to set the ignition timing?
Old Jul 29, 2011 | 02:06 PM
SlayANT's Avatar
x2. Get a paper clip and jump the service connector else the ecu will auto correct the timing.
Old Jul 29, 2011 | 04:47 PM
Cynical 1's Avatar
this is base timing.
Old Jul 29, 2011 | 09:07 PM
I did jump the service connector but still nothing, I do not know if the mechanical timing is correct though, but I do hope so, car drives fine just really sluggish when a/c is on lol
Old Jul 29, 2011 | 09:18 PM
Former User's Avatar
Sounds like the timing is off by one tooth on the timing belt.
Old Jul 30, 2011 | 02:48 AM
HondaPartsHero's Avatar
Technical Hero
This is normal, the Y7 is a gutless wonder.
Old Jul 30, 2011 | 03:49 AM
NACvicSi's Avatar
x2, mine is the same way
Old Jul 30, 2011 | 07:41 AM
Thanks I'm going to check that out as soon as possible
Also wanna say thanks to everyone on here for taking the time to help me out
beocop
Dec 15, 2016 09:05 AM
chengrazng
Aug 23, 2007 11:03 AM
mortificationrock
Jul 10, 2007 04:26 PM
ls-v
10
May 1, 2007 07:43 PM
maxmax
May 14, 2006 03:37 PM
