HELP me fix code 6 and 7!!!
Old Oct 2, 2002 | 05:39 PM
See Are X's Avatar
Default HELP me fix code 6 and 7!!!
I've been driving around for a couple months now with these codes because I dont know how to fix them. Can someone PLEASE help me out??? Code 6 is Engine Coolant Temp. sensor, and code 7 is TPS Sensor...help help help!
Old Oct 2, 2002 | 08:14 PM
poison's Avatar
Default Re: HELP me fix code 6 and 7!!! (See Are X)
The TPS is the Throttle Position Sensor and detects the exact throttle position
the Coolant Engine Temp Sensor is the sensor that tells when your fan will go on or not from the ECU.
You will probably need to replace the engine coolant temp which is by the thermostat, or make sure the wiring is good on it.
as well as the TPS sensor which is right behind the throttle body and is black.
make sure they are plugged in and properly working.
if they are plugged in, you will want to go to a junk yard and get a new TPS sensor as well as the coolant one if you cannot get 'em working.
eghatchfla
May 28, 2010 06:26 AM
mycrx7
Jan 23, 2007 11:21 AM
CIVILGSR
Jul 20, 2003 10:42 PM
igone916
Mar 3, 2003 08:59 PM
90civichbsi
Oct 2, 2002 09:07 AM
