99 si sputtering problem
Old Jul 27, 2011 | 02:29 PM
Thelugie42's Avatar
Default 99 si sputtering problem
I know there is probably another thread addressing this issue but i can't find it so here goes, i have a 99 civic si and every time i shut the car off and then start it back up without letting it sit for at least a half hour it sputters really bad, almost to the point of shutting off, but then after a few minutes of driving it goes back to normal. If the car sits for a while before you restart it, it does not have this problem. I'm sure that it is a sensor or something but i have tried everything, new map sensor, new main relay, new fuel filter, fuel injector cleaner, im out of ideas and need some help, any insight would be greatly appreciated thanks!!!
Old Jul 27, 2011 | 02:44 PM
QuatroAce's Avatar
Default Re: 99 si sputtering problem
Have you cleaned your IACV?
Old Jul 27, 2011 | 02:59 PM
Thelugie42's Avatar
Not yet will try but not really an idleing problem, keep the ideas coming!!
Old Jul 27, 2011 | 03:03 PM
QuatroAce's Avatar
I've been having stuttering issues, mostly at low idle, but also at low RPMs coming off of a stop, cleaned the IACV, fixed both problems.
Old Jul 27, 2011 | 03:23 PM
Thelugie42's Avatar
Alright will try as soon as i get some time and let you know how it goes!
Old Jul 27, 2011 | 10:38 PM
goldenchild707's Avatar
is your primary o2 sensor throwing codes??
Old Jul 29, 2011 | 10:08 AM
ccfootball28's Avatar
has cleaning the IACV fixed the problem?
Old Jul 31, 2011 | 07:44 AM
Thelugie42's Avatar
I haven't got a chance to do it yet, but ill update as soon as its done!
Old Jul 31, 2011 | 08:56 AM
virgineg6's Avatar
Do you have any CELs? When was the last time the car had a full tune up?
Old Aug 6, 2011 | 05:13 AM
Thelugie42's Avatar
Okay finally got to claning the IACV no luck, gunna try replacing the tps to see if that fixes the problem, and i do have a cel but ive had it since ive had the car and this problem is new!
Old Aug 6, 2011 | 05:27 AM
HondaPartsHero's Avatar
Technical Hero
What is the CEL for?
Old Aug 6, 2011 | 09:45 AM
QuatroAce's Avatar
Also might want to try your dizzy timing... Are you sure that it is timed correctly?
sikvic00
44
Apr 7, 2011 05:24 PM
dohcem1
19
Jun 1, 2009 09:35 PM
dohcem1
May 28, 2009 08:07 PM
FearTheH
23
Feb 26, 2008 08:05 PM
jdmstreethatch
Dec 22, 2005 07:26 PM
