Weird idle problem...
Old Dec 20, 2005 | 10:54 AM
jdmstreethatch's Avatar
Default Weird idle problem...
I have a '99 d16y7 and while im driving my car the rpms will drop down to around 450 when i come to a stop or push in the clutch. the lights will dim and the car will act like its going to die. it doesnt do this all the time, just randomly it seems like. Any ideas?
Old Dec 20, 2005 | 01:27 PM
Perfectionist's Avatar
Default Re: Weird idle problem... (jdmstreethatch)
I had a similar problem on my old '90 Civic Si. I also had a very slight surge/lag when cruising at a steady speed about 25mph in 3rd gear. In my case, the O2 sensor was slow/lazy. That was screwing up the fuel trim. An OEM sensor solved the problem after two Bosch generics didn't.
Old Dec 21, 2005 | 05:19 AM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
Check/replace your grounds
Old Dec 22, 2005 | 07:26 PM
rintegration's Avatar
These civics have a problem with the alternator's (If not already replace under warranty back in the day) so make sure its putting out the correct voltage (about 13-15 volts at idle no load).
Dave-Rsxs02
Apr 9, 2016 06:29 AM
djviet2000
Aug 20, 2008 08:19 PM
PinoyCivic
Jan 10, 2006 10:38 AM
90prelude2.0Si
Oct 13, 2005 12:48 PM
Eluzion
May 8, 2003 08:04 AM
