Car is jerking, HELP ASAP Please
Old Jul 27, 2011 | 09:59 AM
iamthefollower's Avatar
Default Car is jerking, HELP ASAP Please
Ok, so yesterday morning I got into my car and was driving to work. While going down the road, when I get to around 3k rpms, in 1st-4th the car starts jerking terribly bad and everything. It will go past 3k rpms, but it gets worse. I really need to get this fixed because it is my Daily atm until I get my wifes car finished. It was fine the night before when I drove it home, just seems wierd to get up and the car be doing this now.
Any help would be greatly appreciated. Everything was the same as it was the night before, just jerking now.
Old Jul 27, 2011 | 10:07 AM
Former User's Avatar
Default Re: Car is jerking, HELP ASAP Please
What car and mods?
CEL codes?
When was the last tune up?
Any dash warning lights?
Old Jul 27, 2011 | 10:15 AM
Originally Posted by RonJ@HT
What car and mods? 96 EX Civic, D16a built, eagle rods, vitara pistons, Eldebrock intake.
CEL codes? Knock sensor, has been like that for the last month.
When was the last tune up? about a month ago when engine was put into the car.
Any dash warning lights? SRS, CEL
Old Jul 27, 2011 | 10:21 AM
How old is the fuel filter. It may be clogged.
Do you have a dead cylinder? Test by unplugging each injector clip one at a time.
Also inspect all ignition components, fix the knock sensor code, and check the mechanical timing.
Old Jul 27, 2011 | 10:32 AM
I don't know on the fuel filter. Would the car die, or just kinda bog when unplugging the injector clips? The knock sensor will only be able to be fixed with a chipped ecu, which I have, just don't have a tune/basemap to run the engine atm. I appreciate the help with try to get this fixed soon.
Also, I have a 00 Si gauge cluster in my car and my wife just told me that when she was driving the Maintenance Required light was blinking.
Old Jul 27, 2011 | 10:37 AM
Not sure how to interpret the effect on unplugging the fuel injector. Might that just be a coincidence?
I mentioned the fuel filter because, if clogged, it would have increasing negative effects on performance at higher engine rpms. Replacing the fuel filter is relatively inexpensive and easy to do. Otherwise, you could measure the fuel pressure and test the FPR while you are at it.
Testing for a dead cylinder is also easy to do.
Old Jul 27, 2011 | 11:07 AM
Brundell88's Avatar
I had the same exact problem with my b16, it was the tps sensor. Check the fuel filter then the throttle position sensor.
Old Jul 27, 2011 | 11:14 AM
Thanks you all, will check those out today. .
Old Jul 27, 2011 | 07:22 PM
Well, I found out what it was. The fuel line was kinked and had a leak coming from it. I got a new one put it on and the car is running awesome now.
Old Jul 27, 2011 | 10:55 PM
altitude_19's Avatar
Interesting stuff. Where was the kink? Was it from prior work or road damage?
Old Jul 28, 2011 | 09:19 PM
It was at the top of the fuel line, on the other side from the fuel rail. It was from previous work, when the motor got put into the car. I replaced it with a new one and no more kinks are in the line.
Dat1BVtecN
Engine Management and Tuning
21
Apr 8, 2009 07:03 PM
95turbodteg
Aug 11, 2007 01:48 PM
SovXietday
Jun 4, 2007 08:21 PM
