something making noise in my gas tank?
Old Jul 27, 2011 | 07:15 AM
swizz977's Avatar
Default something making noise in my gas tank?
1992 civic hatchback sounds like somthings loose and knocking around inside my gas tank .. i went under the car and everything is tight is that possible?
Old Jul 27, 2011 | 09:07 AM
hyperblu's Avatar
Default Re: somthing making noise in my gas tank?
What makes you think its in the gas tank?
Old Jul 27, 2011 | 09:37 AM
grumblemarc's Avatar
The Grumpiest
If it's actually clucking around IN the gas tank then looking underneath the car isn't going to help you. So ditto the question above.
Old Jul 27, 2011 | 11:09 AM
swizz977's Avatar
i think its in the gas tank because like i stated b4 when i drive i hear somthing knockng around.. and when i look under everything is tight.. so im guessing its in the gas tank.. is there anything inside there that might of gotten loose or somthing do you know of
Old Jul 27, 2011 | 12:28 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: something making noise in my gas tank?
Only thing I can think of is the filter sock or the level assembly but it wouldn't make any noise. Could someone have put something down the fuel neck as a joke?
Old Jul 27, 2011 | 01:00 PM
thenext's Avatar
20% cooler
Am I the only one thinking about this?
Old Jul 27, 2011 | 01:27 PM
cheggie's Avatar
The fuel pump could be flopping around - sometimes people don't put the rubber isolator back in. Does the 92 have an access hole for the tank under the rear seat like the later Civics? Next step is to open it up to take a look.
Old Jul 27, 2011 | 04:00 PM
swizz977's Avatar
the fuel pump is inside flopping around in my gas tank probally right.. there is a silver circle thing under the seats is that what ur talking about?
Old Jul 27, 2011 | 04:11 PM
Jdm03's Avatar
have you tried inside the car, maybe? Haven't seen anyone start out with this question 1st.
Old Jul 27, 2011 | 05:53 PM
swizz977's Avatar
no its not coming from inside im pretty sure its in the gas tank i guess its the fuel pump thats loose
Old Jul 28, 2011 | 09:13 AM
hyperblu's Avatar
a loose fuel pump? Then you wouldnt have fuel pressure...
Old Jul 28, 2011 | 01:50 PM
NOFX's Avatar
H-T White Ops
Have you tried having someone sit in the back while you drive so they could attempt to pinpoint the source of the noise?
Old Jul 28, 2011 | 01:51 PM
The Grumpiest
You sure it's not something in the spare tire area?
Old Jul 28, 2011 | 01:58 PM
NOFX's Avatar
H-T White Ops
Dropping the tank isn't hard btw. It's just a pain in the ***.
Run it as dry as possible before you attempt to drop it.
I really think it's unlikely there's something in the tank that's large enough to cause a knocking noise though.
Old Jul 28, 2011 | 02:37 PM
swizz977's Avatar
so ur saying it cant be this if im able to drive ?
Old Jul 28, 2011 | 07:35 PM
hyperblu's Avatar
If you lose pressure in the tank, it would probably throw an emissions code... It would drive, but probably idle like crap...
Old Jul 28, 2011 | 08:08 PM
NOFX's Avatar
H-T White Ops
Fuel tank pressure sensor codes are pretty common ("bad gas cap" is what they're often diagnosed as). They usually run fine.
Not all Hondas have a fuel tank pressure sensor though. I know a '97 Civic CX doesn't, for example.
Old Jul 29, 2011 | 12:49 AM
cheggie's Avatar
It could run perfectly normal with the pump loose, there is a short section of flexible line connecting the pump to the tank hanger.
The fuel pump is accessable under the rear seat, remove the cover in the floorpan, then the lid on top of the tank. No need to drain the tank.
Looking in the tank will take less time than I took to write this reply. I just repaired a car that had a loose pump, someone left out the retaining washer on the bottom. Why don't you look in the tank so you can confirm or deny that this is the problem?
Old Aug 1, 2011 | 06:51 AM
thenext's Avatar
20% cooler
How do you just look in a fuel tank? Wouldn't the baffles block your view?
aasaa666
Dec 27, 2007 03:23 PM
HondaHemi
Dec 3, 2005 05:51 PM
Sam268
Jan 28, 2004 08:24 AM
GruvyTune
Aug 15, 2002 05:10 AM
HondaCivicEx98
Jun 2, 2002 07:18 PM
