Blue smoke problem!!
I got a gsr motor with ctr piston just got it rebuilt from the machine shop but it's smoking blue smoke only when its warm, and when I stop at a light or if I'm on the highway and I slow down it smokes blue and u can smell that it's oil burning... I put an oem headgasket from golden eagle for 81.5 mm which is the perfect fit .. Please help !! What can be causing these smoke!!???
i think you are having a ring problem be it the put them in wrong or the piston to wall clearence is to much. is the machine shop known to do good engine builds?
Your stock head may have been fine on the old block (as htey have worn out together) but with the block redone it is going to have a machined deck. was the head properly machines aswell? i know this is a far fetch but it is however possible. Also have you checked to see while it is running if you are building up crankcase pressure? Pull off the PCV and see how much blowbye you have.
I called the machine shop they told me tht if the rings were bad it would smoke blue all the time not just when the car is warm. He also told to illiminate the black box and if tht dnt work it could be the valve guides!!......
-HONDA-
Oct 2, 2007 09:01 AM
