Rack and pinion boot
Old Jul 26, 2011 | 12:23 PM
jesssssss's Avatar
Default Rack and pinion boot
Aright so on my 94 Del Sol Si my passenger side rack and pinion boot keeps ripping within a few days of replacing and it's not a huge hole either it's a tiny hole on the top part by the inner tie rod. Today is the third time it's ripped causing PS fluid to gush out of there. What could be causing it to rip? Thanks in advance and pics of the boot upon request.
Old Jul 26, 2011 | 12:43 PM
Former User's Avatar
Default Re: Rack and pinion boot
The end seal of the steering rack is leaking. The easiest fix is to replace the rack.
Old Jul 26, 2011 | 01:43 PM
jesssssss's Avatar
Yeah seems like that's what it is. Thanks so much for your help really appreciate it
Old Jul 26, 2011 | 03:58 PM
Civic1.6EX's Avatar
Hey Ron...
I wanted to ask you, is it diffucult to replace the steering rack and pinnon on a 96 Civic?
My driver side boot is ripped and there is a little fluid leaking but my resivor is full everytime I check it.
Thanks in advance for any help you can give..
Old Jul 26, 2011 | 04:02 PM
Originally Posted by Civic1.6EX
Hey Ron...
The end seal is leaking some fluid. Eventually the rack will need to be replaced. The job is very tedious due to inaccessibility to the two fluid line nuts but is doable if you are determined.
forevermemorabl
14
Mar 27, 2014 04:14 PM
05foresterxt
Mar 19, 2011 09:06 AM
hueyduey
May 19, 2007 12:30 AM
goodbyegti
Jun 28, 2004 08:31 PM
