Transmission & Drivetrain Gearboxes, Differentials, Clutches
ATS lsd vss
Old Jul 26, 2011 | 07:25 AM
trincivic's Avatar
Default ATS lsd vss
My speed is not working since i have found out that with the installation of an ATS LSD a new speed gear is required for the sensor.
I have found one with the following measurements Diameter 18.8 mm, thickness 10mm ad 22 teeth
The stock speed gear measured at diameter 22.75mm, thickness 10mm and 20 teeth
Also the gears teeth have different direction as shown in pic
Have anyone came across the spped gear for the cusco, ats, kaaz lsd and what are the dimension
Old Aug 6, 2011 | 09:45 AM
J240sx's Avatar
Default Re: ATS lsd vss
oh snap! i have having the same issue. Apparently the speed sensor that works with the corresponding diff comes when purchased new from manufactured.
Old Aug 6, 2011 | 04:59 PM
F20beast's Avatar
snap! lol im having the same issue on a k20a, 5.8:1 FD
nofrenfish
Jun 25, 2014 03:32 AM
DOHCarp
Oct 21, 2010 08:59 PM
drift2004
Dec 17, 2007 10:46 AM
n1_egsex
Aug 29, 2007 02:44 AM
JDMINTEGRALS
Feb 19, 2006 03:58 PM
