Overheating going uphill on freeway...
It's a 94 gsr motor in a 92 cx. I'm using the cx radiator, and i'm wondering if that's the problem.
Today on the way to school, going uphill on the freeway, the temp. went about 3/4 and was inching it's way to about 4/5.... pulled off the freeway and it came down.
the fan comes on, city driving it's surprisingly cool, no leaks.... the thermostat is working good...
I just changed the coolant, replaced the fan with the fan from my old 01 gsr...
recommendations? i'm going to change the radiator as soon as possible, I was looking into the GSR, but we're installing the turbo in a couple of weeks, so there might be a clearance issue?
Not enough coolent, when at an angle (uphill) engine doesn't pull enough coolent.
Clough in lines; you might want to "super" flush.
You didn't unscrew bleed screw when filling.
Few things to check for.
hotcivicsi
Feb 25, 2009 05:05 AM
civicmatt
13
Sep 25, 2003 11:40 AM
