"92 Civic not running
Old Jul 25, 2011 | 08:52 PM
lancerswimmer89's Avatar
Default "92 Civic not running
Ok, heres the story. '92 Civic hatch, d16z6, 5spd trans.
One day, my brother is driving this car, and it all of the sudden just dies at idle, and won't start back up again. We figure its a ignition issue so we replace everything, and still nothing. After a week of toying w/ it, we take it to the shop around the corner.
Got a call today saying that there is bad compression on cylinder #4, only 50 psi, but the rest are fine. Also, that timing may have jumped (damn ***-hats didn't even pull the timing cover to find out), and they are recommending the engine be replaced.
Could it be a top end problem? Maybe a bent valve from the timing slipping? Or a blown headgasket causing a drop in compression? I need help asap guys so i can get this thing back on the road, and save it from the crusher since thats what my dad is gonna do if it isn't fixed in a week.
Thanx
Old Jul 25, 2011 | 09:07 PM
Former User's Avatar
Default Re: "92 Civic not running
Sounds like a bent valve from jumping time. Pull off the head to verify.
Or do a cylinder leak down test.
Old Jul 25, 2011 | 09:33 PM
i've seen video's on how to do those, but i don't have a leakdown tester or a stethoscope...is there any way to improvise these devices?
Old Jul 27, 2011 | 07:15 PM
ok, so i re-set the timing, and tried turning it over, but got nothing.
once that was done, i did my own compression test, and got a solid 150 across the board on ALL of the cylinders.
anybody else have any ideas as to why it won't start? EGR Valve? ECU?
Old Jul 27, 2011 | 09:40 PM
Dave87's Avatar
My friend had the same problem where it died at idle. Changing the distributor and checking the grounds and sanding down those points solved his issue, if this doesn't work for you I'd suggest taking a look at the ecu and seeing if it went bad.
Old Jul 27, 2011 | 11:10 PM
altitude_19's Avatar
You've got compression. Have you checked all the ignition leads for spark? You can take a spare plug, ground it, and plug leads into it one by one to make sure they all spark. If that check out, you're left with a fuel issue.
Old Jul 28, 2011 | 06:45 AM
its getting strong fuel pressure, as well as strong spark
Old Jul 28, 2011 | 06:44 PM
Would it still pass compression if it was out of time? Checked fuses? Maybe something blew in fuel management (injection, maybe?).
tim73
Jan 4, 2016 07:52 AM
elsicario12
10
Aug 14, 2013 12:46 PM
Panoply
14
Jun 5, 2012 07:38 AM
memorybox
May 13, 2009 01:01 PM
thdog1
Apr 30, 2008 06:09 PM
