95 del sol si: Car sputters at high rpms and engine light comes on.
Old Jul 25, 2011 | 07:10 PM
osbunjosh's Avatar
Default 95 del sol si: Car sputters at high rpms and engine light comes on.
Today i was coming down the highway and decided to get on it for a minute. Nothing a normal honda guy wouldnt do. In 3rd gear at about 5000-6000 rpms it felt like it was losing power but after 6000-7000 rpms it came back. Then my engine light came on. When i got off i had to stop for a red light. Turned the car off and back on and no engine light. Anyone have any ideas?
Old Jul 25, 2011 | 07:40 PM
Former User's Avatar
Default Re: 95 del sol si: Car sputters at high rpms and engine light comes on.
Even though the CEL is off, jump the service connector in an attempt to retrieve the code. If none is recovered, the next time the CEL turns on, pull over and leave the engine running while you jump the service connector.
Old Jul 25, 2011 | 07:42 PM
osbunjosh's Avatar
Well it happened once before like 3 days ago and when i got home i was going to check it on the service connector but i couldnt find it. I have a haynes manual but still couldnt find it. It is located right above the ecu correct? under the glove box area? is there a trick to finding it cause i looked every where
Old Jul 25, 2011 | 08:09 PM
It's often plugged into a rubber holder. Click on the CEL sticky at the top.
jena_blondie
18
Oct 7, 2017 07:43 PM
hondacivic97si
Jun 16, 2015 10:37 AM
adez1313
Feb 23, 2013 04:57 PM
Guitarzann
Dec 13, 2005 10:21 AM
bjm01843
Feb 14, 2004 12:36 PM
