please help me car wont start!!!!!!!!!!!
Old Oct 2, 2002 | 02:08 PM
TRENDSETTLER's Avatar
Default please help me car wont start!!!!!!!!!!!
i just installed a header and testpipe on my 99 gsr...when pluggin in the o2 sensors my friend accidentally plugged it in backwards at first...we started the car and it started fine but died as soon as i tried to drive it...we jacked it back up and noticed the plug was backwards and flipped it the right way but it still wont start anybody have any idea what i can do...any help is greatly appreciated
thanks
josh
Old Oct 2, 2002 | 02:13 PM
GZERO's Avatar
Default Re: please help me car wont start!!!!!!!!!!! (TRENDSETTLER)
did you try reseting the ECU?
Old Oct 2, 2002 | 02:14 PM
Default Re: please help me car wont start!!!!!!!!!!! (GZERO)
yes i tried the ecu...please help me...
Old Oct 2, 2002 | 02:16 PM
GZERO's Avatar
does it gives you any CEL codes? did you check the fuses?
Old Oct 2, 2002 | 02:18 PM
poison's Avatar
jump the ECU and see if there is any codes.
car will not start w/o the o2 sensor properly installed and working.
Old Oct 2, 2002 | 02:19 PM
i thought i couldnt get a cel unless the car is running...because i thought if you had the car in the "on" position the cel was always illuminated...i didnt check any fuses...what would i look for in the fuse box?
Old Oct 2, 2002 | 02:22 PM
GZERO's Avatar
the ecu and injection fuse might be blown, is just a guess, and i was asking if it gives you any CEL the lil while the car was on. what does the car sounds like when you try to turn it on?
Old Oct 2, 2002 | 02:25 PM
there was no cel when the car was running....car sounds totally normal when tryin to start it up...it sounds like im out of gas or the battery is dead but i checked the battery and it says its good...how would i check the fuses..thanks for the help
what exactly do i need to do to "jump the ecu and check for codes"?
Old Oct 2, 2002 | 02:27 PM
poison's Avatar
is the starter turning the motor over?
and it will not show CEL's with the key in the on position unless you have it jumped.
There is a green box above the ECU, one set of them have 3 wires, and the other have 2.
take a paperclip and put them into the 2 wire connector and jump the 2 wires then count the CEL
Old Oct 2, 2002 | 02:29 PM
GZERO's Avatar
what car is this? do you have a helms manual?
Old Oct 2, 2002 | 02:30 PM
Default Re: please help me car wont start!!!!!!!!!!! (poison)
the started will turn over it just wont start...i will search for a paper clip to try to get the cel its under the kick panel on the passenger side right? is it possible that the engine is just fludded from trying to start the car so much and tappin the gas pedal?
Old Oct 2, 2002 | 02:32 PM
its a 99 gsr...i dont have a helms manual
Old Oct 2, 2002 | 02:34 PM
GZERO's Avatar
do a search on hot to read codes on your car, and don't step on the gas trying to turn it on, they don't need that at all, it just make things worst. go look for the codes and come back
Old Oct 2, 2002 | 02:37 PM
i already know how to read the codes...just makin sure it where the ecu was....poison already explained how to read them
Old Oct 2, 2002 | 02:46 PM
GZERO's Avatar
ok, did it threw any code?
Old Oct 2, 2002 | 02:50 PM
poison's Avatar
ya, it's on the passenger side panel. just pull the carpet, and look all the way up there and you will see the bix green box (it's rubber coated)
Old Oct 2, 2002 | 02:56 PM
ok...i jumped the ecu...and turned the ignitioin "on"...the cel light came on but didnt flash...it just stayed illuminated...did i jump it correctly because without the ecu jumped doesnt the light always come on and stay on till you start the car?
Old Oct 2, 2002 | 02:59 PM
poison's Avatar
ok, you are not throwing any codes. the CEL staying lit up means there is no codes stored when the ECU service connector is jumped.
now, on to more troubleshooting.........the starter does turn the motor over correct?
Old Oct 2, 2002 | 03:00 PM
yes the motor will turn over
Old Oct 2, 2002 | 03:18 PM
GZERO's Avatar
i know this doesn't have much to do with this, but does it gives you spark?
lets say since the sensor was plugged in wrong at first then i fixed it...if the sensor was fried wouldnt the car still start and just throw a cel?
Old Oct 2, 2002 | 03:19 PM
poison's Avatar
ok, next thing you need to check is for spark and fuel.
take out the spark plug wire and put a screw driver in it, then put that next to the radiator support (about 2 mm gap) and have someone crank it over.
you should see a spark out of that. check all 4 cylindars.
you should also smell fuel from the combustion chambers...
let me know what's up then...
if the car is turning over it just wont start...im not sure if it is giving a spark
Old Oct 2, 2002 | 03:20 PM
poison's Avatar
w/o the o2 i don't believe it'll start, if it does start it will throw the o2 code and throw you in limp mode.
reason is the ECU does not know what air/fuel ratios to put in the motor and doesn't know the engine load, etc.
