please help me car wont start!!!!!!!!!!!
Old Oct 2, 2002 | 03:21 PM
  #26
GZERO's Avatar
Default Re: please help me car wont start!!!!!!!!!!! (TRENDSETTLER)
dude there are so many variants here, and i don't know all of them
i'm telling you the ones to look for to see if something helps
poison you look like you know more, try to see if you can help him
[Modified by GZERO, 4:23 PM 10/2/2002]
Old Oct 2, 2002 | 03:22 PM
  #27
TRENDSETTLER's Avatar
im not sure i completely understand...you want me to pull the plugs out of the holes and put a screwdriver in them...and put by the rad support???? i can smell fuel after i crank it over...is it possible the engine is fludded from tappin the gas while tryin to start it so much..would this keep it from starting?
Old Oct 2, 2002 | 03:27 PM
  #28
gzero...i dont really know what you are talking about...thanks for trying to help
poison thanks for you help and if you could explain the spark plug thing again i would appreciate it
Old Oct 2, 2002 | 03:29 PM
  #29
GZERO's Avatar
what i was saying is just take out one spark plug, connect it to the cable and tell somebody to try to turn it on, you should be able to see sparks coming out of the spark plugs, that's all i want to see now
  #30
poison's Avatar
ok, you are getting fuel...
take out the spark plug wire...
take a screw driver (flat head or phillips, doesn't matter), put it inside the spark plug wire.
then take that wire with the screw driver in it in, and it it about 2 mm from the radiator support (a little gap), have someone crank over the motor and see if there is spark.
do this on all 4 cyl
Old Oct 2, 2002 | 03:31 PM
  #31
GZERO's Avatar
Default Re: please help me car wont start!!!!!!!!!!! (poison)
my guess would be all of them would be the same, don't you think with one would work?
Old Oct 2, 2002 | 03:55 PM
  #32
Default Re: please help me car wont start!!!!!!!!!!! (GZERO)
ok if i did that thing correctly then i have absolutly no spark at all....i did it the way that said take out the wire, unscrew the plug and stick it in the wire and hold it close to the metal of the radiator support...i also tried the screwdriver...no sparks...what now?
Old Oct 2, 2002 | 03:56 PM
  #33
also the tips of my plugs were dark brown...normal?
Old Oct 2, 2002 | 04:02 PM
  #34
GZERO's Avatar
this is all too weird, i think brown is ok, but why there isn't any spark? i'm thinking the ECU is not ok, did you check the fuse? i don't know where's the fuse box in that car, find out, look for the ECU fuse and see if the wire that is visible is not blown
Old Oct 2, 2002 | 04:07 PM
  #35
bruthaboost's Avatar
I haven't read that you've checked the fuses in your engine compartment fuse box. Just for grins, check all your grounds (a loose thermostat ground can cause the symptoms your describing).
BTW you really should by a helms. They're only 64.00 and it'll be the best money you'll spend on your ride.
Old Oct 2, 2002 | 04:10 PM
  #36
Default Re: please help me car wont start!!!!!!!!!!! (bruthaboost)
can you help me out as to where to check the thermostat ground...im not sure where that is
Old Oct 2, 2002 | 04:15 PM
  #37
GZERO's Avatar
i don't think he has to go that basic, the car would start with that unplugged and probably throw a code for it, but i guess the car would start. yeah, i'm wating for him to check the fuses
Old Oct 2, 2002 | 04:24 PM
  #38
i was goin through the fuses and found a blown one....fuse 15a...on the panel it says FI E/M...any ideas???
Old Oct 2, 2002 | 04:29 PM
  #39
GZERO's Avatar
change it, is Fuel injection. tell me what happends after change it
Old Oct 2, 2002 | 04:33 PM
  #40
cant i change it with another fuse temporarily till i buy a new one?
Old Oct 2, 2002 | 04:36 PM
  #41
GZERO's Avatar
NO! obviosly something wasn't right, so is not advisable, what you can do is take another fuse (same amperage) of some accesory that is not that important and put it in the place of FI E/M, something temporally just to see if it works fine, but i would advise to go tomorrow and buy it, you can even try a gas station right now, they usually have at the end of that dark hall
[Modified by GZERO, 5:37 PM 10/2/2002]
Old Oct 2, 2002 | 04:43 PM
  #42
YumVTEC's Avatar
Yeah, your car will definitely not start with that blown. I had my secondary o2 sensor short out between two of the four wires (the shielding melted) and it popped that fuse on me. I replaced the fuse and it popped again right away. I didn't know it was my secondary o2 wiring until I did a little looking around. Found the short, taped things up, replaced the fuse, and Voila... the car starts and runs fine.
FI E/M I believe controls the ignition relay (hence no spark), or it could be the ECU fuse or both. Couldn't tell you without my service manual in front of me to reference.
Great that you found that fuse and that's all it was. I'm confident your car will start fine with that fuse replaced.
Old Oct 2, 2002 | 04:46 PM
  #43
GZERO's Avatar
Default Re: please help me car wont start!!!!!!!!!!! (YumVTEC)
It stands for Fuel Injection and Engine Manegement. Yeah, that is definetly the reason why it wasn't turning on, he only needs to change the fuse
Old Oct 2, 2002 | 04:55 PM
  #44
poison's Avatar
yes you can i wouldn't recommend it though.
so you are getting no spark? check fuses...yes. replace all blown fuses with no higher than 5 over the AMP if not the same
Old Oct 2, 2002 | 04:56 PM
  #45
poison's Avatar
Trevor said it all
Old Oct 2, 2002 | 05:55 PM
  #46
hey guys sorry it took so long to update you i ran to auto zone and got some fuses...and it worked!!! i drove the car home from my friend's house and it seems to be running fine now...hopefully it wont blow again...im goin to jack it up again in the morning and check and make sure the sensor wires are fine...thank you guys for all the help i seriously appreciate it a lot...HT is the best...i would still be sittin around without a clue...thanks again
miguey310
Sep 13, 2011 07:55 PM
BiG_DeE
Mar 23, 2010 04:47 PM
paowa
18
Apr 20, 2009 09:02 PM
M2B4
Jul 8, 2007 01:43 PM
huntarrr
Jun 29, 2004 09:42 AM
