jumpy idle??
Old Jul 23, 2011 | 08:06 AM
oakman513's Avatar
Default jumpy idle??
b16 with jumpy idle. Engine code with map sensor code 3 and fuel code 43. replaced map sensor. still same problem. any help would be great. Thanks.
Old Jul 23, 2011 | 01:01 PM
civickiller's Avatar
Default Re: jumpy idle??
mixed up MAP and TPS?
Old Jul 24, 2011 | 09:31 AM
hybridmiklo's Avatar
if you replaced the map sensor and the light is still on for it then there is obviously a wiring problem with the map. Check for its 5volt reference, check that there is still a ground, and also check the signal wire.
As for the code 43 that most likely has to do with the incorrect air fuel mixture do to the map problem.
Bswapped
Jun 20, 2015 02:22 PM
chucky86
Oct 13, 2011 02:46 PM
Tex Blackwell
Apr 13, 2005 04:03 PM
chrysler kid
Sep 28, 2004 07:24 PM
