cheap B series swap?
Old Jul 22, 2011 | 08:07 PM
nicholasm's Avatar
Default cheap B series swap?
im running a d16 right now and im looking for a cheap B swap.
what would be second next to the b20?
Old Jul 22, 2011 | 11:29 PM
CivicBlacksheep's Avatar
10 Year Member
Default Re: cheap B series swap?
LS.....b20....
Old Jul 23, 2011 | 02:11 AM
Wilka's Avatar
B18b ls with gsr vtec head?
Old Jul 23, 2011 | 02:39 AM
NotAJDMFanBoy's Avatar
It used to be that the B20 was cheap. You had the B20B (lower compression) and the B20Z (higher compression). The B18a/b was either in between the two in price, or it was 3rd cheapest. Then the B16A. Next, B18C1. B18C5. And most expensive, B16B
The order has changed recently it seems. The B20 has gotten more popular and the prices have gone up. The B20, B18 "LS", B16 and B18C1 are your main choices. Depending on your budget and availability of each, will determine which is the best choice in your situation.
Old Jul 23, 2011 | 10:17 AM
Str8EJ's Avatar
The least expensive B would be a stock B18a paired with either a hydro or cable LS trans, depending on the chassis in which the drivetrain will be installed.
Old Jul 23, 2011 | 12:09 PM
cleepyek's Avatar
wheres a good place to look for those motors?
Old Jul 23, 2011 | 12:17 PM
Str8EJ's Avatar
junk/salvage yards, engine importers, private sellers, enthusiast forums, online shops, local classifieds.
Old Jul 23, 2011 | 02:55 PM
disaster's Avatar
I ended up getting a good deal on a b18 swap out of a riced out integra. the kid wanted 400 bucks for the whole car. I brought it home, tore it out, and scrapped the car. There are typically a decent amount of deals like that on craigslist. granted ill be way over $400 dolars when this swap is complete...
Old Jul 23, 2011 | 05:14 PM
cleepyek's Avatar
having a donor car like that^^ would save me alot of money and time looking for other various parts ill need right?? because besides the motor what else woult one need??
Old Jul 24, 2011 | 07:44 AM
Red_Army's Avatar
axles, ecu, and the trans.
Old Jul 24, 2011 | 09:53 AM
owneyboy's Avatar
el ez... lol what a pathetic useless swap.... b16 what a waste. only cheap swap isnt worth it. "go big or go home" "do it right the first time"
Old Jul 26, 2011 | 01:21 AM
b18EK6's Avatar
Did you take the rear disk setup off the teg before you scrapped it, would be a shame if you didn't.
Old Aug 6, 2011 | 12:30 PM
disaster's Avatar
Unfortunately i didnt! i had no way of getting rid of the shell without all the suspension components, and i didnt have enough time to do the brake swap before i had to scrap it.
Old Aug 6, 2011 | 01:06 PM
FlewByU352's Avatar
I'd go with a B18C
Old Aug 6, 2011 | 01:09 PM
Wrona's Avatar
Originally Posted by FlewByU352
I'd go with a B18C
cause thats totally cheap
Old Aug 6, 2011 | 02:14 PM
f88bonilla's Avatar
Jdm engines u can find good engines
Old Aug 6, 2011 | 05:18 PM
AztecEGhatch's Avatar
definitely look on your local craigslist, you can usually find a swaps used for cheaper than ebay or places that sell JDM engines (a lot of people are ditching their swaps to go k-series) also look at integras like disaster said
Old Aug 6, 2011 | 05:51 PM
grumblemarc's Avatar
The Grumpiest
Don't buy an engine off of Craigslist. How do you know what condition it's in?
Old Aug 6, 2011 | 08:33 PM
Wrona's Avatar
unless ur rebuilding the engine anyway and u can get a GSR swap for 250 bucks like i did a couple weeks ago
Old Aug 6, 2011 | 09:05 PM
98civdx's Avatar
Master Detailer
Is it stolen?
Old Aug 6, 2011 | 10:06 PM
Wrona's Avatar
Originally Posted by 98civdx
Is it stolen?
no it has all the vin tags spun bearing
Old Aug 7, 2011 | 08:09 AM
apexi_rsx's Avatar
he needs the front spindles off the integra as well B series axles wont fit a civic spindle
Old Aug 7, 2011 | 09:15 AM
98civdx's Avatar
Master Detailer
You sure about that?
What makes them different? keep in mind ALL USDM B series/D series are 32mm. Only difference is the JDM ITR with 36mm.
The axles are different and will need to be swapped to B series, but the knuckles are just fine.
91CrxMann
34
May 15, 2015 05:15 AM
89prelude069
Jul 26, 2010 06:40 AM
integraNooB
Apr 14, 2008 05:26 PM
lrcrx90
81
Jun 1, 2006 06:14 AM
live_again_integra
Feb 10, 2005 08:28 AM
