Help On PO453 Check Engine Light
It's On A 96 Honda Civic. I Don't Not Know Where Abouts Is The Fuel Tank Pressure High Input Is At. Is It Inside Of The Fuel Tank?? Or OutSide The Tank??? Any Help Will Be Great.
So I Put A New Gas Cap On YesterDay. Drove The Car All Day And Nothing. So I Went This Morning And Turned On The Car. 5 Seconds Later Light Back On. FML
TRhis is what i found on google closest thing its from a 01-05 civic should be smilar
P0453 Troubleshooting
1. Check the vacuum lines at the FTP sensor. Make sure they're not kinked, cracked, leaking, broken, clogged, etc.
Are the vacuum lines okay?
Yes - Go to step 2.
No - Repair or replace the bad vacuum line(s).
2. Reset the ECU. (Remove fuse #6 (15A) from the under-hood fuse box. Wait at least 10 seconds before putting it back in)
3. Remove the gas cap.
4. Turn the ignition switch ON (II)
5. Monitor the FTP sensor voltage with the HDS, or measure the voltage between a body ground and ECM/PCM connector terminal E14.
Is there about 2.5 volts?
Yes - Intermittent failure. System is okay, but check for loose wires or poor connections at the FTP sensor and the ECM.
No - Go to step 6
6. Turn the ignition switch OFF.
7. Put the gas cap back on.
8. Disconnect the FTP sensor 3-pin connector.
9. Turn the ignition switch ON (II)
10. Measure the voltage between FTP sensor connector terminals #1 and #2.
Is there about 5 volts?
Yes - Go to step 15
No - Go to step 11
11. Turn the ignition switch OFF.
12. Disconnect ECM/PCM connector E. (31-pin)
13. With a jumper wire, ground FTP sensor connector terminal #2
14. Check for continuity between ECM/PCM connector terminal E4 and body ground.
Is there continuity?
Yes - Swap your ECM with a known-good one and re-check. If the problem does not return, the problem was the ECM.
No - Repair an open in the wire between the FTP sensor and the ECM/PCM (E4)
15. Measure the voltage between FTP sensor connector terminals #2 and #3.
Yes - Replace the FTP sensor.
No - Go to step 16
16. Measure the voltage between ECM/PCM connector terminals E4 and E14.
Yes - Repair an open in the wire between the FTP sensor and the ECM/PCM. (E14)
No - Swap your ECM with a known-good one and re-check. If the problem does not return, the problem was the ECM.
Yes - Go to step 2.
No - Go to step 6
Yes - Go to step 15
No - Go to step 11
No - Go to step 16
trouts2
Nov 23, 2016 05:54 PM
blackhope121
Apr 11, 2005 12:26 PM
