engine wont rev past 3500rpms help asap!
Old Jul 20, 2011 | 07:33 PM
biggreenz's Avatar
Icon3 engine wont rev past 3500rpms help asap!
i checked my cel 93 hatch blinked 16 times and 21 time. it started when i decided to power shift from 1st to second had some wheel hop then started doin this so i gues i rattled somthin loose maybe? so i need help asap what should i look for? any help would be HIGHLY appreciated
Thanks, Ryan
Old Jul 20, 2011 | 07:43 PM
Former User's Avatar
Default Re: engine wont rev past 3500rpms help asap!
Is one of the fuel injectors not pulsing fuel?
Old Jul 20, 2011 | 08:37 PM
biggreenz's Avatar
not sure havent taken them out to check. will hardly idle an not start some of the time i was out there messing with it...motor is a b18c1
Old Jul 21, 2011 | 02:29 PM
NotAJDMFanBoy's Avatar
Get a long handle screwdriver and use it like a stethoscope to listen. Put the driver end on the injector and handle to your ear and don't get it in the belts or anything high voltage.
Old Jul 21, 2011 | 03:03 PM
biggreenz's Avatar
injector clip was loose runs fine now besides it still throwin 21 how can i fix that take it off clean it? wiring possible?
Old Jul 21, 2011 | 03:30 PM
ktsciv93's Avatar
21 is vtec solenoid. make sure ur solenoid and pressure sensor didn't come unplugged.
also check for a loose ground
Old Jul 21, 2011 | 07:31 PM
biggreenz's Avatar
ok ill check that in the mornin but vtec is working jus feels kinda weak could possibly be dirty or not good conection?
codylesak
Oct 14, 2010 06:32 PM
dboysi03
Mar 28, 2010 02:20 PM
redxcobrax
11
Jun 12, 2009 10:37 PM
Maple50175
Engine Management and Tuning
Sep 15, 2008 10:44 PM
10seceg
Jan 1, 2004 03:36 PM
