engine wont rev past 3500rpms help asap!
i checked my cel 93 hatch blinked 16 times and 21 time. it started when i decided to power shift from 1st to second had some wheel hop then started doin this so i gues i rattled somthin loose maybe? so i need help asap what should i look for? any help would be HIGHLY appreciated
Thanks, Ryan
Thanks, Ryan
Re: engine wont rev past 3500rpms help asap!
not sure havent taken them out to check. will hardly idle an not start some of the time i was out there messing with it...motor is a b18c1
Get a long handle screwdriver and use it like a stethoscope to listen. Put the driver end on the injector and handle to your ear and don't get it in the belts or anything high voltage.
injector clip was loose runs fine now besides it still throwin 21 how can i fix that take it off clean it? wiring possible?
21 is vtec solenoid. make sure ur solenoid and pressure sensor didn't come unplugged.
also check for a loose ground
